C4005 loader?
/ C4005 loader? #1
DHF3
Mahindra C4005-DI
Recently a friend gave me their 2001 Mahindra C4005-DI tractor. It only had 185hrs, but had been sitting idle (under cover) for the past 5-8 years. I spent considerable time cleaning/rebuilding the injector pump, injectors, fuel lines, hydraulic lines, etc. and now it runs like new. My question is about suitable front end loaders. I’d like to add this implement, but I’m having difficulty finding info on which model(s) (Mahindra or others) would be appropriate for this tractor. Also, what if any, modifications to the current hydraulic system may need to be made to operate a front loader? FYI…with this tractor I was also given: 6’-shredder, 6’-disker; auger w/boom attachment; 300lb-spreader/seeder; 6’-road grader; 2-blade plow.
/ C4005 loader? #2
Recently a friend gave me their 2001 Mahindra C4005-DI tractor with 185hrs. With this tractor I was also given: 6’-shredder, 6’-disker; auger w/boom attachment; 300lb-spreader/seeder; 6’-road grader; 2-blade plow.
Lucky you.
I’d like to add a suitable Front End Loader but I’m having difficulty finding info on which model(s) would be appropriate for this tractor.
/ C4005 loader? #3
Lucky you.
the C4005D-I looks like a good heavy tractor, tractordata indicates a 8.3 gpm flow which is not bad.
I would contact WESTENDORF
they manufacture FELs for all makes of tractor. just be prepared, good advice is to buy the tractor with a loader in the first place because it is expensive to add after unless you are good at heavy fabrication, then you can make just about anything fit (just need a bigger hammer lol)
2015 Ford F-550 4x4 Liftmoore 2550 5,000lb. Crane Service Truck (A64556)
2015 Ford F-550...
2008 SELLICK S-80 ROUGH TERRAIN FORKLIFT (A65053)
2008 SELLICK S-80...
2014 Hyundai VI2530112 53ft. T/A Dry Van Trailer (A64556)
2014 Hyundai...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
7 foot bucket (A64194)
