C4005 loader?
/ C4005 loader? #1
DHF3
Mahindra C4005-DI
Recently a friend gave me their 2001 Mahindra C4005-DI tractor. It only had 185hrs, but had been sitting idle (under cover) for the past 5-8 years. I spent considerable time cleaning/rebuilding the injector pump, injectors, fuel lines, hydraulic lines, etc. and now it runs like new. My question is about suitable front end loaders. I’d like to add this implement, but I’m having difficulty finding info on which model(s) (Mahindra or others) would be appropriate for this tractor. Also, what if any, modifications to the current hydraulic system may need to be made to operate a front loader? FYI…with this tractor I was also given: 6’-shredder, 6’-disker; auger w/boom attachment; 300lb-spreader/seeder; 6’-road grader; 2-blade plow.
/ C4005 loader? #2
Recently a friend gave me their 2001 Mahindra C4005-DI tractor with 185hrs. With this tractor I was also given: 6’-shredder, 6’-disker; auger w/boom attachment; 300lb-spreader/seeder; 6’-road grader; 2-blade plow.
Lucky you.
I’d like to add a suitable Front End Loader but I’m having difficulty finding info on which model(s) would be appropriate for this tractor.
/ C4005 loader? #3
Lucky you.
the C4005D-I looks like a good heavy tractor, tractordata indicates a 8.3 gpm flow which is not bad.
I would contact WESTENDORF
they manufacture FELs for all makes of tractor. just be prepared, good advice is to buy the tractor with a loader in the first place because it is expensive to add after unless you are good at heavy fabrication, then you can make just about anything fit (just need a bigger hammer lol)
1995 FORD F-SERIES S/A GRAIN TRUCK (A64278)
1995 FORD F-SERIES...
2012 FORD E-350 CUTAWAY SERVICE BODY TRUCK (A67148)
2012 FORD E-350...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
