Landscaping with a tractor?
   / Landscaping with a tractor? #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
I have a fairly heavy tractor over 4000 pounds without attachments.
Attachments I possess: Tuffline heavy single Ripper, Howard 60" select-a-tilth, two bottom 16" plow, FEL, heavy 6 tine cultivator, Worksaver snow pusher w/ rubber edges, HLA grapple.
I have springs and low spots where the springs make the most trouble. This is in the 3-acre lawn part of the property, there are more springs in my other 3 acres of woods and swamp out back, but the state EPA won't let me touch them. YAY AMERICAN FREEDOM~!!!
The swamping is so bad that I often have to drag my lawnmower out of the muck, then abandon that part of the yard till drier times.
My land slopes downhill away from the house into the back and down into the woods. So there's that. I am at 700 Feet above sealevel
Mind you I've tried ripping. It doesn't seem to help.
I have dirt, lots and lots of dirt. The town was doing sidewalks and I told the contractor that I'd take his dirt. He was happy.
The soil down a foot or so has lots of clay it tends to clog drainage. Twice I've put a dump truck of rock and perf pipe in the same run and didn't know enough to use a sock and both times the clay blocked it up. I dug that trench by hand. Heavy forged bar, pickaxe, and shovel. That clay is tough
But things got worse.
More springs erupted with climate change. Last some odd years, we have been getting a different weather pattern than before in living memory. It rains and rains and rains in the spring then we get what metrologists are calling Rain Bombs too regularly for the land to dry up. It sort of does dry up in the high summer but never quite
This is where I run into a decision.
Do I dig and install drainage pipe gravel and sock it?
Or should I try using all that dirt to raise the land where I have swamping taking place?
If I dig I'll use the tiller and ripper and FEL to get a nice deep trench.
Or I can just build a screen sifting my free dirt and carry it over to the low spots?
Have you dealt with this? Know anyone who has?
   / Landscaping with a tractor? #2
Have you considered a mole plow? Basically a subsoiler/ ripper that drags a ‘torpedo’. The torpedo creates a channel that aids drainage. Not very common in North America but something to consider.
I am wanting to stick with the tools at hand.
But I just went looking at these things. I don't see that it'd be any more effective than my honkin' big subsoiler. Ostensibly it makes a little burrow in the soil which I'd counter would fill in almost as soon as water hits the tunnel. The subsoiler rips up earth making t for a more robust cut and removing soil from the ground
Which also tends to fill in.
It is not out of the question that I could put a honkin 3 or 4 or even 6" torpedo on a chain behind my ripper. But would it really make the difference?
And another thing:
Where do you position the depth of cut? Below or inside the clay layer
   / Landscaping with a tractor? #5
Can you make a drainage ditch or what farmers call a water way to channel the water vs trying drain tile? This provides a place for heavy rains to go and don’t plug as easily as drain tile.
I have a 50-yard one. It was the reason I hand-dug the aforementioned ditch in the first place. It's b rutally ugly and a PITA to mow around. With the water table as it is these days I'd need a spider web of them.
   / Landscaping with a tractor? #7
You asked the EPA for permission? Isn't it easier to get forgiveness than permission?
   / Landscaping with a tractor? #8
I would plow it up let it dry and hit it with the tiller since you do not have a disk. The once it’s all nice and fluff drag it with som railroad ties and chain link fence. Dragging it will level out the area and get you ready for seed prep. Also keep your eyes on Craigslist for a box scraper and cut some swales to assist in drainage
good question
In New Jersey The State EPA trespasses.
They send engineers to survey your land (without asking you) and if they find a droplet of water they map it and then forbid you from so much as having a dream about improving the land within 350 feet of the drop of water.
Then they have more engineers who fly around in helicopters over your land to see if you are violating the law that they never told you about.
Then they send more engineers to trespass again to see if you did it in a surreptitious way.
If you did then you can (a) have your property seized by the state and they will drain it and put up a parking lot or (b) pay an enormous fine and have to pay someone else to undo what you did, or (c) I think there are executions in secret.
Almost no one knows about these things.
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
500BBL WHEELED...
New/Unused Mini Skid Steer Attachment Set A (A57454)
New/Unused Mini...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56436)
2017 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
