'73 Ford 4000 3 point doesn't work
/ '73 Ford 4000 3 point doesn't work #1
jshwhite
Gold Member
Missouri
Kubota L4740, Massey 65, Case 580C
I'm considering purchasing a 73 Ford 4000 diesel for a bushhogging tractor. Haven't looked at it yet but the guy says it runs great and has no issues other than "the 3 point doesn't work". He said the implement dealer told him it is probably a pin that came loose inside because it runs the PTO off the same pump. 🤷‍♂️
I'm pretty good with wrenching but don't have much knowledge of the hydraulics on these tractors. I don't mind a repair if I can get it for the right price, but would like a reasonably good diagnosis before buying it. Anyone know what might be the problem?
/ '73 Ford 4000 3 point doesn't work #2
It is really hard to diagnose the problem over the internet without a lot more detail. I would not trust the guy that is selling you the tractor. The older model tractors are generally fairly easy to work on.
Here is a series of videos on the ford series of tractors like yours.
Hope this helps!!
Thanks! Yeah I know it's hard to say just from a description online. Just thought I'd ask in case maybe someone else had a similar problem. I talked to a friend who has worked on these a lot and he said probably just an issue in the linkage/activation, since the rest of the hydraulics work.
/ '73 Ford 4000 3 point doesn't work #4
Good luck and let us know how it goes!! I really like those older tractors.
/ '73 Ford 4000 3 point doesn't work #5
Piston under seat. Clean and replace seal.
Solved my problem on ford 1900 when I first got it running after years in the barn.
Thanks. Good to know. I ended up not getting the tractor, but hope to get one soon.
New/Unused Landhonor Quick Attach Grapple Bucket (A65583)
New/Unused...
3142 (A63117)
3142 (A63117)
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
