'73 Ford 4000 3 point doesn't work
/ '73 Ford 4000 3 point doesn't work #1
jshwhite
Gold Member
Missouri
Kubota L4740, Massey 65, Case 580C
I'm considering purchasing a 73 Ford 4000 diesel for a bushhogging tractor. Haven't looked at it yet but the guy says it runs great and has no issues other than "the 3 point doesn't work". He said the implement dealer told him it is probably a pin that came loose inside because it runs the PTO off the same pump. 🤷‍♂️
I'm pretty good with wrenching but don't have much knowledge of the hydraulics on these tractors. I don't mind a repair if I can get it for the right price, but would like a reasonably good diagnosis before buying it. Anyone know what might be the problem?
/ '73 Ford 4000 3 point doesn't work #2
It is really hard to diagnose the problem over the internet without a lot more detail. I would not trust the guy that is selling you the tractor. The older model tractors are generally fairly easy to work on.
Here is a series of videos on the ford series of tractors like yours.
Hope this helps!!
Thanks! Yeah I know it's hard to say just from a description online. Just thought I'd ask in case maybe someone else had a similar problem. I talked to a friend who has worked on these a lot and he said probably just an issue in the linkage/activation, since the rest of the hydraulics work.
/ '73 Ford 4000 3 point doesn't work #4
Good luck and let us know how it goes!! I really like those older tractors.
/ '73 Ford 4000 3 point doesn't work #5
Piston under seat. Clean and replace seal.
Solved my problem on ford 1900 when I first got it running after years in the barn.
Thanks. Good to know. I ended up not getting the tractor, but hope to get one soon.
John Deere 6200 Tractor (A64047)
John Deere 6200...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
8" Mini Excavator Bucket (A66285)
8" Mini Excavator...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
