Moving a shed
/ Moving a shed #161
BEF,
Maybe a third hinge to stop mid door sag/warp?
Really fun watching the transformation.
/ Moving a shed
BEF,
I never had a problem with doors sagging since it’s one sheet of wood, 7 ft tall. Not a bad idea though. A couple of the lag holes are getting worn. I can fix that with new frame on the inside. If I don’t get the shed moved, it will at least get new sides and a new look.
Here’s the left door lagged into place top to bottom with a couple 2x4s also lagged to the header and the floor. Love these timber lock bolts. And my battery impact driver.
/ Moving a shed
Got ambitious after mowing today and got the other door done
Didn’t get the fillers in above the doors, need trimmed a little, and I didn’t trim enough, and got too tired.
/ Moving a shed #165
Funny how "Moving a shed" became "Cleaning out and refurbishing a shed". No criticism intended. I've been following every step.
/ Moving a shed
Cleaning out was always the first step before moving, but that never got finished.
Was going to refurbish after the move, but since it looked like the move wasn’t happening soon, decided to fix it up first.
I’m hoping prices on PT 6x6s come down some.
/ Moving a shed
Think the all gray is pretty drab though. Maybe I should paint on a trim to match the barn trim.
/ Moving a shed
The old color was barn red. It clashed with the barn when I built it, hence the gray to blend in.
/ Moving a shed
Worked a little on the shed. Took off the next panel, discovered bottom piece very rotten. Moved my stack of leftover shingles from that corner of shed, flooring is a bit rotten also. Will probably cut out a 2x4 ft section and replace.
But not tonight, so tacked up the new piece with a few screws for now.
When I had that piece open, blew out some of the floor with leaf blower.
/ Moving a shed
Light rain, no hint of as much of a breeze, so good morning for a camp fire to get rid of more wood.
Fire has really singed the oak tree leaves.
/ Moving a shed
More cleanup inside today. Lot of stuff burned.
/ Moving a shed #176
Is that saved cat litter? Purpose?
/ Moving a shed
It’s builders sand, in old cat litter buckets. I have a whole bunch more in buckets under the open shed. Probably will just dump it out.
/ Moving a shed #179
Or save for icy winter…
/ Moving a shed #180
I think I see some nice looking poplar boards sitting there.... they could be turned into some nice woodworking projects!
2016 Cadillac CTS Sedan (A64557)
2016 Cadillac CTS...
2012 . Tri Axle Crude Trailer (A67714)
2012 . Tri Axle...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
2018 Toro Workman HDX-D Diesel Utility Cart (A66734)
2018 Toro Workman...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
