Manual tree pole pruner, what's the trick?
/ Manual tree pole pruner, what's the trick? #42
What do you mean by 'nibbling'? Are you trying to get through a branch with multiple nibbles? If so, that won't work very well, if at all.
I have a Fisker's pole pruner similar to the one you linked to. Every branch I cut with it is cut with one pull of the rope. If the branch doesn't fit into the opening, I use the saw instead of the pruner.
To cut a branch with the saw, make a cut 1/3 of the way through the branch from the underside, then make a 2nd cut from the top, about an inch outward from the first cut. The branch will fall and snap off instead of stringing the bark and/or wood out.
Same here....exactly. (y)
/ Manual tree pole pruner, what's the trick? #46
I looked for an electric saw with a 20+ foot pole and apparently, there isn't one.
That would be extremely unwieldly to handle. The weight of the head would counter act the handle. I use the HF Portland 110 volt electric pole trimmer in conjunction with an extension cord and my portable gas driven Inverter generator in the back of the side-by-side.
My only issue with the Portland trimmer is it's very small bar oil tank which necessitates filling often.
/ Manual tree pole pruner, what's the trick? #47
Approximately sixty years ago, a right of way crew came through the yard and before my elders snatched me away from the great event, I got a glimpse of a worker using the shear on the end of a pole to nibble away at a large branch and cut it. The closest thing I was able to find to that pole pruner should appear at the following link: https://www.amazon.com/dp/B09G9TTH5..._product_details#immersive-view_1652926294760
I recently bought that pruner and the problem I'm having is that on the first bite the blade gets caught in the branch and it takes a great amount of manuvering to get it out and take another bite. i've already broken the rope once, trying to cut straight through a large branch. The saw works , but I'd like to lean to use the the nibbling technique with the shear.
If anyone knows the trick to nibbling through a limb with a rope operated pole pruner, please let me know.
Try here...lots of good pole saws
/ Manual tree pole pruner, what's the trick? #48
I would need about 1000 ft of extension cord. Not practical.
Very practical for me. Genny in the bed of the side by side and a 25 foot extension cord to the pole trimmer. The inverter genny I use (Champion 2000 watt) is very portable, sips gas and has automatic idle down when nothing is drawing power. On fact I use it quite a lot in the side by side for powering 110 volt tools in the field. No need to be concerned with rechargeable tools running low on power.
/ Manual tree pole pruner, what's the trick? #49
I ended up buying this unit: https://www.baileysonline.com/jameson-ja-34-big-mouth-line-clearance-pruner-kit.html
I have cut up to 1-1/2" limbs with it and I am 78 years old.
I had the big box stores units and they have trouble cutting anything but really small limbs. They seem to get jammed a lot as was mentioned earlier.
You can buy just the head for less money but be sure you buy the compound pulley setup. This pulley system makes a huge difference but you need to pull twice the rope thru to make the cut. I have an electric trimmer but the higher you go the harder it is to control. I rarely use the electric because of my lack of control. Using either electric or the pruner mentioned above you will end up at some point under part of the limb when it comes down. Wearing a good arborist hard hat with face shield will save an eye/head injury and trip to emergency room.
/ Manual tree pole pruner, what's the trick? #51
Oil the joint well and make sure that the bolt that holds the pivoting cutter is not too tight.
/ Manual tree pole pruner, what's the trick? #52
I have the 14' Corona manual Tree Pruner and it works fine for "live" tree pruning and can shear a limb up to about 1 1/2" before it starts to get difficult. I sharpen the blade occasionally, the saw works fine. The manual pruner has more difficulty cutting dead / dry hard wood limbs. I also use an electric pole saw (Portland from HF) around my camp & house where I have power. It was not expensive and is easy to use, never had a problem other than needing to sharpen the chain, so, I did purchased a three pack of extra chains online and always have a sharp one on standby. My brother just bought a 14' gas Husqvarna pole saw. He uses it around his house but I plan to borrow it for use in the woods to cut shooting lanes. ;-)
/ Manual tree pole pruner, what's the trick? #53
I have a 16' ECHO gas pole pruner with a 12" bar, and it is a bear to handle at full length, especially if you're stretching for that last extra foot. But it is a brute chain saw for its size. I've used it for 8" limbs and it goes!
/ Manual tree pole pruner, what's the trick? #55
I too have a manually saw and procrastinate having to use it. If I had many trees to trim I would have to look closely at this saw from Northern Tools. A hydraulic saw for the bucket.
/ Manual tree pole pruner, what's the trick? #56
Having just spent a chunk of money for a tree service to cut some trees for me, my advice is not to procrastinate. Spending money on a good power pole saw today and actually using it before your trees grow out of control might save you a lot of money later.
5x10 Utility Trailer (A61165)
5x10 Utility...
2021 Dodge Durango SUV (A61569)
2021 Dodge Durango...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
UNUSED WOLVERINE SB66-66" ROCK BKT (A62131)
UNUSED WOLVERINE...
1976 T/A RGN Low Boy Trailer (A61568)
1976 T/A RGN Low...
Here are some similar links:
