Manual tree pole pruner, what's the trick?
/ Manual tree pole pruner, what's the trick? #51
Approximately sixty years ago, a right of way crew came through the yard and before my elders snatched me away from the great event, I got a glimpse of a worker using the shear on the end of a pole to nibble away at a large branch and cut it. The closest thing I was able to find to that pole pruner should appear at the following link: https://www.amazon.com/dp/B09G9TTH5..._product_details#immersive-view_1652926294760
I recently bought that pruner and the problem I'm having is that on the first bite the blade gets caught in the branch and it takes a great amount of manuvering to get it out and take another bite. i've already broken the rope once, trying to cut straight through a large branch. The saw works , but I'd like to lean to use the the nibbling technique with the shear.
If anyone knows the trick to nibbling through a limb with a rope operated pole pruner, please let me know.
Oil the joint well and make sure that the bolt that holds the pivoting cutter is not too tight.
/ Manual tree pole pruner, what's the trick? #52
I have the 14' Corona manual Tree Pruner and it works fine for "live" tree pruning and can shear a limb up to about 1 1/2" before it starts to get difficult. I sharpen the blade occasionally, the saw works fine. The manual pruner has more difficulty cutting dead / dry hard wood limbs. I also use an electric pole saw (Portland from HF) around my camp & house where I have power. It was not expensive and is easy to use, never had a problem other than needing to sharpen the chain, so, I did purchased a three pack of extra chains online and always have a sharp one on standby. My brother just bought a 14' gas Husqvarna pole saw. He uses it around his house but I plan to borrow it for use in the woods to cut shooting lanes. ;-)
/ Manual tree pole pruner, what's the trick? #53
I looked for an electric saw with a 20+ foot pole and apparently, there isn't one.
I have a 16' ECHO gas pole pruner with a 12" bar, and it is a bear to handle at full length, especially if you're stretching for that last extra foot. But it is a brute chain saw for its size. I've used it for 8" limbs and it goes!
/ Manual tree pole pruner, what's the trick? #55
I too have a manually saw and procrastinate having to use it. If I had many trees to trim I would have to look closely at this saw from Northern Tools. A hydraulic saw for the bucket.
/ Manual tree pole pruner, what's the trick? #56
Having just spent a chunk of money for a tree service to cut some trees for me, my advice is not to procrastinate. Spending money on a good power pole saw today and actually using it before your trees grow out of control might save you a lot of money later.
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
PT 6'x16' 4 Wheel Farm Wagon (A60463)
PT 6'x16' 4 Wheel...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
Here are some similar links:
