Manual tree pole pruner, what's the trick?
/ Manual tree pole pruner, what's the trick? #31
Diggin It,
Could you give me a name or link to a commercial version that reaches 30 feet or more?
As a professional arborist (at that time) everybody in the business used a Marvin pole saw. Like most all arborists, I used it on a 12' pole exclusively.
Never liked nor wanted a pole using extensions - too sloppy.
Most companies advertise using extensions. That is only because it is easier to ship! 12'poles must go by freight.
To get a 12' pole, the best place is at an arborist supply, not likely near you, unless you are in a major city.
The run of the mill crap they sell to consumers is absolute junk!
Note: always cut perpendicular to the branch you are cutting. A small stub is ok!
/ Manual tree pole pruner, what's the trick? #32
Make sure it's sharp with a fine rat tail file and lube it with bar oil or something. It won't nibble, test the sharpness.
/ Manual tree pole pruner, what's the trick? #34
I've got a Fiskars pole pruner: General PDP Template | Canadian Tire and find it works great. Anything that doesn't fit in the shears gets cut with the saw which cuts like a hot knife thru butter. I use it every fall to trim the pines and spruce and the occasional hardwood.
Just last weekend cut some 3-4" branches off a pine tree that were hanging over the powerlines to my house. They were so far up the sin had to use a ladder with the shaft of the trimmer extended all the way..........M
/ Manual tree pole pruner, what's the trick? #35
I have a 40 volt wen battery pole saw that extends out , I have cut 8 inch oak limbs with it , it is way better and easier to handle than the gas one i have.
I have a manual limb pruner/saw - just like yours stuckmotor. It works EXACTLY like yours also. I trim the limbs on the pine trees that line my driveway. I do not like - even hate - this job. I know, in advance, it's going to be a frustrating project.
MANY years ago - at the Kubota dealer. The salesman had a hydraulic powered limb pruner. It was just like our manual unit except hydraulics off the tractor activated the jaws. It was a quite heavy unit and NOT something I would want to be lugging around all day. Then there would be the hydraulic hose that you would be dragging around also.
I use the saw portion of mine about 80% to 90% of the time. I use mine until I get very tired OR pissed off. That's it for the day. I'll go again another day.
Oosik,
On Wednesday, I had my three week eye check and the doctor finally said I cou!d exert myself. The first strinuous thing I did was try out the saw. Ater three weeks of inactivity, it tired me out quickly and made me irritable.
I hope your eye is healing well.
/ Manual tree pole pruner, what's the trick? #38
I beleive 8 ft. And it is very light and easy to control.
/ Manual tree pole pruner, what's the trick? #39
I own three pole saws, all with engines. Can you guess what I'd say?? :p
/ Manual tree pole pruner, what's the trick? #40
Moss,
You're probably right. I don't remember exactly how the rope was strung through the pulleys, before it broke, but I don't think it was the way I have it now. There are some pictures on my phone and when I remember how, I'll try to get them up.
Hopefully it's just something simple like that. :)
CAT D8 (A58214)
CAT D8 (A58214)
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
Kuhn FC400RG (A60462)
159116 (A60430)
159116 (A60430)
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
FIFTH WHEEL ATTACHMENT PLATE (A60736)
FIFTH WHEEL...
Here are some similar links:
