Manual tree pole pruner, what's the trick?
/ Manual tree pole pruner, what's the trick? #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
Approximately sixty years ago, a right of way crew came through the yard and before my elders snatched me away from the great event, I got a glimpse of a worker using the shear on the end of a pole to nibble away at a large branch and cut it. The closest thing I was able to find to that pole pruner should appear at the following link: https://www.amazon.com/dp/B09G9TTH5..._product_details#immersive-view_1652926294760
I recently bought that pruner and the problem I'm having is that on the first bite the blade gets caught in the branch and it takes a great amount of manuvering to get it out and take another bite. i've already broken the rope once, trying to cut straight through a large branch. The saw works , but I'd like to lean to use the the nibbling technique with the shear.
If anyone knows the trick to nibbling through a limb with a rope operated pole pruner, please let me know.
/ Manual tree pole pruner, what's the trick? #2
It could be the quality of the pruner. I wouldn't trust any of their reviews. I've a couple of manual ones and never found the pruner to be effective, rather 6 cuts with the saw would take down a 1" to 2" hardwood branch.
It could well be he quality of the pruner. The right of way crew probably had a commercial model. The throat on this one is larger than that on one I bought from a big box store but, the blade comes more or less, from the bottom causing it to be pinched.
/ Manual tree pole pruner, what's the trick? #5
I use one of those.
The trick is to not put any pressure on it, like you otherwise would with a bow saw. Just let the blade rest on the branch and start sawing. The course blades will start biting; just keep sawing ( fast and shorter bites seem to work better - use just about half of the blade before you reverse into the other direction).
/ Manual tree pole pruner, what's the trick? #6
First, a rule-of-thumb: Don't stand under the pruner!
If the falling branches don't get you the "sawdust" might fall in your eyes and gift you with a very bad day.
Secondly, there's a reason you cut, sand, drill, etc against a heavy platform, table, vice, etc - so what you're working on can't move.
So what to do?
Well I favor the electric saw on a pole and reaching out not up. Make a shallow cut up from the bottom and _then_ cut the branch off from the top.
So what to do?
I looked for an electric saw with a 20+ foot pole and apparently, there isn't one.
/ Manual tree pole pruner, what's the trick? #8
I don't know of a 20+ electric pole saw you can buy, either. There's a good chance there would be too much leverage to handle easily.
/ Manual tree pole pruner, what's the trick? #10
I have a manual limb pruner/saw - just like yours stuckmotor. It works EXACTLY like yours also. I trim the limbs on the pine trees that line my driveway. I do not like - even hate - this job. I know, in advance, it's going to be a frustrating project.
MANY years ago - at the Kubota dealer. The salesman had a hydraulic powered limb pruner. It was just like our manual unit except hydraulics off the tractor activated the jaws. It was a quite heavy unit and NOT something I would want to be lugging around all day. Then there would be the hydraulic hose that you would be dragging around also.
I use the saw portion of mine about 80% to 90% of the time. I use mine until I get very tired OR pissed off. That's it for the day. I'll go again another day.
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2016 Chevrolet Caprice Sedan (A61569)
2016 Chevrolet...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
CFG Industrial 680 QA Hydraulic Hummer (A60463)
CFG Industrial 680...
2019 Ford F-150 XL (A60462)
2019 Ford F-150 XL...
2013 FORD F-350 SERVICE TRUCK(INOPERABLE) (A60736)
2013 FORD F-350...
Here are some similar links:
