If it's worth doing it is worth overdoing
/ If it's worth doing it is worth overdoing #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
a lousy clamp for a lousy box to put lousy chains in. It's mostly made from scrap.
8 Helicoils with detents so it shouldn't work itself loose.
No one will ever accuse me of being a welder.
/ If it's worth doing it is worth overdoing #3
Haha, not bad!
Does it... .dump itself every time you lift the loader all the way up, though? Why not mount it somewhere... fixed?
Excellent question.
I shall bookmark this thread and wait for some one more perspicacious to answer.
Coz I sure as **** couldn't find it.
It's an ammo box the closure is quite good.
I might have put it inside the tube that spans the FTL members but I want that for another purpose.
/ If it's worth doing it is worth overdoing #6
You guys got it wrong.... that's for the self dumping feature ! Easier to pick up the chain off the floorboard than take it out of the box......:unsure::unsure::unsure:
Just kidding.... a very nice job for sure. Were there supposed to be poor welds in the pictures? They work, they hold, can't see them when the box is on.... GOOD TO GO!
/ If it's worth doing it is worth overdoing #7
Here's a few pics of mounting tool boxes to the ROPS. The plates holding the boxes are bigger than the cheap plastic HF boxes. My intentions are to get the boxes like you have. These were just laying around and used as a 'prototype'.
A442F219-CB69-4F23-A10B-F318C795A2E4.jpeg4C129A07-EC64-4598-B88A-F197E8B04E8A.jpeg5F3299D2-E6E5-4804-8415-AA61A41BF283.jpeg
They work for me as is, so until they break, I'll use them as is.
/ If it's worth doing it is worth overdoing #8
That's looks to be a pretty solid setup, ammo cans are great.
/ If it's worth doing it is worth overdoing #9
While it shouldn't come off, I would have mounted it the other direction. Would stay closed easier. But I wouldn't have put it there in the first place either. I think it is way too high. Stand on the wheel to put the chain back up or get it out? But it's your machine, not ours. Thanks for posting, I like mount.
/ If it's worth doing it is worth overdoing #11
It all looks great. The paint helps the welds. Cosmetics are important after all :) I really like the use of the rubber sheet. I have some rubber sheet left over from a job I did years ago and it is still in very good shape and your post reminded me that I still have it. Thanks. . I want to add a couple chain boxes and the mounts will be clamped to the ROPS. Using rubber sheet like you did will make the mounting much better.
Tomorrow I will be posting some pictures showing some extensions I made for the bucket mounts on my Yanmar YM2310. It's my bad luck that your post is so close in proximity time wise to mine because your work looks so good.
Cheers,
Eric
/ If it's worth doing it is worth overdoing #13
Excellent question.
Perspicacious! Great word.
There's plenty of fixed places to mount an ammo box, if that's what you meant. The stationary part of the loader frame, the rops, besides the floorboard/step, etc.
/ If it's worth doing it is worth overdoing #15
Sure don't, good point. That only removes the ROPS idea, though.
/ If it's worth doing it is worth overdoing #16
Nice, but... The brackets need grade 8 bolts...
/ If it's worth doing it is worth overdoing #17
Dad's solution on our old 3020 John Deere for mounting a box.
And all the area around the cab where one might have found a good anchor on exposed frame but for the cab. I've considered a couple frame members lower down, but I worry that my work in the brush would end up ripping 'em off.
/ If it's worth doing it is worth overdoing #19
6x6” square tubing carries chains, chainsaw, long tools, buckets, gas and oil. Provides skid protection for loader control valve and hoses. Have ammo can too for tractor pins and tools. Carrying tools safely to work with is a necessary part of our farm operations
/ If it's worth doing it is worth overdoing #20
Going through brush and stuff, haven't had a problem, box been there for over 10 years.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2019 INTERNATIONAL LT625 SLEEPER (A59905)
2019 INTERNATIONAL...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
