What have you done to your Branson today?
/ What have you done to your Branson today? #1,081
Spent several hours cleaning the radiator, condenser, oil cooler, and hydraulic cooler on my Branson 8050.
They have two screens in front of everything of course you don't just slide them out, 4 thumb screws for one and then
a slotted tab with a 12 mm bolt (recessed) so you can drop it and fish for it. And no hinges to move and separate things.
So lots of unbolting and bracket moving after removing the air cleaner housing.
This was the first time of going that deep into the cleaning, I've been just removing the screens and using the air wand
and then the water wand to flush them out. Today separated every thing blew them out flushed them out then used a foaming coil cleaner,
and then flushed and blew out again. Then put everything back together.
About 5 hours all told. Getting wet and cussing a bit, missing how nice the PUMA 125 is wing bolts and hinged so you can swing them apart easily.
I've only ever just used the air wand from behind on mine. I can get between the cooler and the radiator a little bit on the left side, but not so on the right side due to the way the brackets are situated.
I've not yet done the task the way you did, just looks like a pain to get everything apart. I can't even get my screen out from in front of the radiator without taking the air cleaner assembly off. No idea who thought that was a good layout.
I tell myself I'm doing it "good enough", it does prevent it from overheating. And I do get quite a bit of chaff blowing out the front when I'm blowing through the back side of the radiator.
But I do wish it was easier to take it apart and blow it clear.
/ What have you done to your Branson today? #1,082
Interesting that on my 15 series I can remove the screen with no problem. Just have to have the loader lifted high enough to clear.
I also can get the radiator genie in between the radiator and condenser to blow the condenser out.
I do wish it had a screen in front of the condenser as it would help some.
/ What have you done to your Branson today? #1,083
Today I was mowing another place we inherited recently that is severally overgrown since, well, since the almost the entire mountain burned on a massive fire in 2005. This place is a 20 to 25 degree slope, so very tricky to work on, specially when there hidden holes from the stumps that burned on that fire, along with fallen rotten trees from previous storms. Extreme care and attention is required to mow it.
Anyway, the place is somewhat dislocated from the village but has a paved road to it which only means one thing. That people will go there to dump all kinds of trash. Turns out I found a piece of broken glass that cut right through the front tire but somehow didn't reach the tube.
Now, do you guys know if this can be fixed somehow, or should I start looking for either a new tire or an used one? The cut it about 1 1/2" long.
/ What have you done to your Branson today? #1,084
View attachment 745755 View attachment 745756 View attachment 745757
I would break it down and put a boot patch in it and see if it would hold. I have had good success with that before. I even had a buddy use CA glue on a gash in the sidewall of his pickup. He wore that tire out and never had another flat on it. Lol
Something like this.
/ What have you done to your Branson today? #1,085
I would do the boot patch like the previous poster, but I would also sew the hole together. Use an awl and some bailing wire. Or perhaps fill the hole with some kind of liquid rubber that hardens
/ What have you done to your Branson today? #1,086
I have used superglue to fix cuts in bicycle tires. You need a way to spread out the cut to get the glue in there. On a bike tire I can pinch the tire and flex the casing to open up the cut. That's probably a lot more difficult with a tractor tire, especially if it's still mounted on the rim.
If there's a chunk missing then the superglue won't work.
/ What have you done to your Branson today? #1,087
Thanks for the ideas guys. I'll see if I can source some big patches locally and work something out. I have a couple tire shops within 2 or 3 miles, maybe they have something like that.
/ What have you done to your Branson today? #1,088
Some of the older tire repair shops could vulcanize sidewall and tread areas. I've also seen tires sewn up with heavy cord and light wire. I was not impressed with the light wire it actually cut it's way through the rubber.
A heavy boot on the inside for strength then rubber cement and sewing for the gap.
Unless you can find a shop that will vulcanize it.
/ What have you done to your Branson today? #1,089
Good ideas...I'd also start saving for a new tire if the patch fails. Glad it was the tire and not your foot!
/ What have you done to your Branson today? #1,090
I agree. I've been saving for the hydraulic oil and filter change that is now due, now I need to add a bit more that that fund.
I grew the habit of using safety shoes pretty much all the time I'm working anywhere, so I don't worry too much about that but it's definitely a concern to keep in the back of my mind.
/ What have you done to your Branson today? #1,091
A slight update on the tire situation. Went ahead and took it to the tire shop. The tire is on the vulcanizing machine as we speak. They had to put an huge patch as it had a little bit more damaged than anticipated once they took it apart.
Thanks again for all the suggestions. I'll be looking for a smaller patch kit or something for smaller punctures, just to have on hand.
/ What have you done to your Branson today? #1,092
I really wish my dealer could get some stock in; I've narrowed myself down to the 2515h and Kioti CK2610, but how can I get a proper feel for something I can't touch?
That's a bummer! I just bought my 2515H on Friday... I couldn't believe how many the dealer had! He sells Mahindra and Branson. He told me that they have sold 14 tractors this month and 11 of them were 2515s.
I was down to the same two options you are, but the all cast construction, weight and lifting capacity of the Branson, both front and rear, made my decision for me. Incidentally the salesman said he has a Mahindra he bought before he even worked there but his next tractor would be Branson because of the lifting capacity.
I take delivery at the end of this week after they install the additional hydraulics I bought with it...Can't wait!
/ What have you done to your Branson today? #1,093
Wow,
That's a lot of tractors on the lot.
/ What have you done to your Branson today? #1,097
Bought mine from them, sight unseen and have been 100% happy!
/ What have you done to your Branson today? #1,098
Super happy to hear that! They seem very solid to me. It's about a 3-½ hour drive from where I live, but worth it to get what I want... and a good dealer to boot makes it all the better!
/ What have you done to your Branson today? #1,099
My dealer was telling me it's damn difficult to get enough product in because it's being sent where Branson is more popular, which is apparently in the South and West Coast; they can never get enough in, one or two at a time, and they're about sold the minute they show up.
Congratulations on the 2515H, they're quite impressive!
/ What have you done to your Branson today? #1,100
Make a Road trip to Wisconsin and I'll let you try it for a week .... As long as my wife's Honey Do List
gets done :)
2013 International WorkStar 7400 4x4 Altec AM55E 56ft. Bucket Truck (A61568)
2013 International...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
2002 Hyster C330B Tandem Smooth Drum Roller (A61567)
2002 Hyster C330B...
FORKLIFT (A56857)
FORKLIFT (A56857)
BUNDLE OF MISC SIZE USED TIN UP TO 26' LONG (A62131)
BUNDLE OF MISC...
UNUSED WOLVERINE TDB-11-84W 84" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
