Indicator light for 0 pressure well
/ Indicator light for 0 pressure well #1
Swede229
Weekend warrior 1025r
Ok, older farmer, doing cancer treatment. Cant go out as much as he used to. Common issue for watering his cattle, is the well. He wants a light installed outside (most likely red), so he can see it from the house. But doesn't care about it running, or holding pressure. He just wants the light to be on when he has a "0" pressure reading, so he knows well has an issue.
Thank you in advance for any help
/ Indicator light for 0 pressure well #2
Pressure switch set to close the contacts at some pressure lower than normal operating pressure would work. Could possibly get second well pressure switch and just set lower the one operating. This way switch is rated for water service.
/ Indicator light for 0 pressure well #3
I have thought about this for my own well. I would do what @oldnslo suggests for a red light, and a second light wired in parallel with pump to flash green when the pump is running to catch things like an open faucet.
All the best, Peter
/ Indicator light for 0 pressure well #4
This is what I did. Added a tee, short hose and a water pressure gauge where it is easily visible:
/ Indicator light for 0 pressure well #5
That's the logical place to put it, but it sure made me smile. :)
/ Indicator light for 0 pressure well #6
Yep, I can relieve my pressure and check the well tank pressure at the same time. :D
/ Indicator light for 0 pressure well #7
I like @oldnslo 's suggestion. Would also add another light (green or blue) connected to the power feed side to monitor if power is out or not as well.
/ Indicator light for 0 pressure well #8
Any pressure switch will work. Just set it lower than the switch that runs the pump. If the extra switch sees low pressure and makes the contacts, you can wire a light or anything to the switch to alert the owner. This is better than a light on the main pressure switch, as the light could be on when the switch is telling the pump to run, but the pump might not be working.
I love the pressure gauge on the crapper! Looks like something I would do. Lol!
Year: 2014 Make: Buick Model: Encore Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 153,674mi (A61574)
Year: 2014 Make...
Arrowquip Heeler Portable Corral (A64047)
Arrowquip Heeler...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63118)
2021 Takeuchi...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
Four (4) Michelin 520/70R38 Mega Bib Floater Tires (A63116)
Four (4) Michelin...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
