Rotary cutter preference
/ Rotary cutter preference #1
Brady D
Southern Middle Tennessee
Ford 1910, Case farmall 95, John Deere 317g
What brand of rotary cutter have you had the best luck out of or prefer the most
/ Rotary cutter preference #2
I’ve only owned LandPride and have been satisfied with both I’ve owned. There are a lot of good cutter brands. Deck steel thickness, gearbox, and mounting frames are what I would inspect before buying.
/ Rotary cutter preference #3
Tennessee River is good.
Had a Big Bee before, it was constantly shaking bolts loose and there was no access holes to change the blades.
/ Rotary cutter preference #4
My Bush Hog has held up great.
/ Rotary cutter preference #5
I have a woods a wallace and a grizzly , all are good cutters. Really depends on what you need to cut and how much you want to spend,
/ Rotary cutter preference #9
Woods, my Woods Brushbull is hands down the best rotary cutter I've ever owned, or even used.
I have three Woods rotary cutters, right now.
SR
/ Rotary cutter preference #10
The major brands will be competitive in design & build, and likely price if you have multiple retailers. As said above, just be careful about the model. Light low end ones up to nice heavier models. I would avoid the low end economy models.
/ Rotary cutter preference #11
I think it starts with what you need to do.
I ran a rebuilt Big Bee 5 footer last summer and it did a good job. I put a heavy duty stump jumper on it and Tractor supply blades. I replaced the main bolts on the A frame and added lock nuts. Probably have $500 in it total including purchase used.
My JD 5 footers do a good job but now you're talking a more expensive cutter.
Haven't tried the 5 foot Brush Bull yet.
I think establish what you need then get something appropriate.
Also, really learn how to set it up and use it properly and it should last a good long time.
I’ve heard some good things about the land prides
I’m looking at a woods they seem to be well built
All brands have different models. I have found spending more on the front end saves money and time on repairs down the road.
Yeah buy once cry once is the saying for that
Yeah the low end modes cannot hold up for many years
/ Rotary cutter preference #18
I don’t think that’s true unless you abuse them, and even then nothing some touch up with a welder can’t fix. I’m not even sure what would constitute a “high end” rotary cutter.
/ Rotary cutter preference #19
The one I had wasn’t rated for what I did so it did not hold up the standards are meant for tall grass only pretty much
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
ASV RC85 Skidsteer (A66285)
ASV RC85 Skidsteer...
GATOR UTV (A63276)
GATOR UTV (A63276)
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
Peterbilt 379 with a CAT C13 (A63688)
Peterbilt 379 with...
