Top Link Jam Nut
/ Top Link Jam Nut #1
N750A
East Tennessee
Kubota MX5400
I've got a new Kubota MX5400. The top link on the 3-point hitch has a jam nut to keep it from losing adjustment. Does the jam nut just need to be hand-tight, or should more torque be used such as tightening with a wrench?
/ Top Link Jam Nut #3
I don't use a manual toplink anymore but when I did I did the same as Bill. Sometimes they will tighten themselves enough you have to use a wrench to loosen them.
/ Top Link Jam Nut #8
My top link never comes loose but my side link moves all the time if i dont tighten it , Especially with the brush hog,
/ Top Link Jam Nut #9
I would snug up the jam nut with a wrench. I have a hydraulic top link now. SOOOOO.. much better.
/ Top Link Jam Nut #11
On my JD the top link has little levers sticking out to turn it. I often get the jamb nut where I want it and then use the levers on the top link to tighten it up to the jamb nut. It seems to hold.
/ Top Link Jam Nut #12
I give a small tug with a wrench on the jam nut. My problem is when removing the implement I sometimes forget to loosen the jam nut BEFORE I pull the pin at the implement connection. If I do that I have problem loosening the jam nut when I mount the next implement. Just a maddening pain.
gg
/ Top Link Jam Nut #13
My Deere 855 came with 3" studs welded to each side of the nut. No tools needed.
/ Top Link Jam Nut #15
My experience is it needs to be wrench tightened.
/ Top Link Jam Nut #16
I have a Kubota M7060. I tighten it with a wrench and it will still loosen after several hours with the 10 foot flail. Drives me crazy.
I wonder if two nuts would be a cheap better system. Like the way two nuts on a steel fishing rod reel seat rarely loosen. Only one nut on a steel reel seat is useless.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
Skid Steer Tree Puller (A65640)
Skid Steer Tree...
2022 EZ-GO ELITE...
Toro LX460 Riding Mower (A65579)
Toro LX460 Riding...
2012 Ford E-350 16ft. Box Truck (A64556)
2012 Ford E-350...
