Top Link Jam Nut
/ Top Link Jam Nut #1
N750A
East Tennessee
Kubota MX5400
I've got a new Kubota MX5400. The top link on the 3-point hitch has a jam nut to keep it from losing adjustment. Does the jam nut just need to be hand-tight, or should more torque be used such as tightening with a wrench?
/ Top Link Jam Nut #3
I don't use a manual toplink anymore but when I did I did the same as Bill. Sometimes they will tighten themselves enough you have to use a wrench to loosen them.
/ Top Link Jam Nut #8
My top link never comes loose but my side link moves all the time if i dont tighten it , Especially with the brush hog,
/ Top Link Jam Nut #9
I would snug up the jam nut with a wrench. I have a hydraulic top link now. SOOOOO.. much better.
/ Top Link Jam Nut #11
On my JD the top link has little levers sticking out to turn it. I often get the jamb nut where I want it and then use the levers on the top link to tighten it up to the jamb nut. It seems to hold.
/ Top Link Jam Nut #12
I give a small tug with a wrench on the jam nut. My problem is when removing the implement I sometimes forget to loosen the jam nut BEFORE I pull the pin at the implement connection. If I do that I have problem loosening the jam nut when I mount the next implement. Just a maddening pain.
gg
/ Top Link Jam Nut #13
My Deere 855 came with 3" studs welded to each side of the nut. No tools needed.
/ Top Link Jam Nut #15
My experience is it needs to be wrench tightened.
/ Top Link Jam Nut #16
I have a Kubota M7060. I tighten it with a wrench and it will still loosen after several hours with the 10 foot flail. Drives me crazy.
I wonder if two nuts would be a cheap better system. Like the way two nuts on a steel fishing rod reel seat rarely loosen. Only one nut on a steel reel seat is useless.
New/Unused CFG Industrial NT18K Mini Excavator (A65579)
New/Unused CFG...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
Connect CH65 Hydraulic Breaker Excavator Attachment (A64194)
Connect CH65...
Kinze 3600 Wiring Harness (A65640)
Kinze 3600 Wiring...
