No till planters
/ No till planters #1
Brady D
Southern Middle Tennessee
Ford 1910, Case farmall 95, John Deere 317g
Has anyone on here used a no till planter before and if so how well did it work
/ No till planters #2
It really comes down to the soil conditions. If your soil is dried out, clay like, and behaves like cement, then don't go this route.
If your soil is rich, dark, soft (not compacted) and will not blow away in wind gusts, then it's for you.
I have one plot this year to experiment without tilling. Took 3 years of compost and disc'ing the nutrients in ever so easy last Fall. We also do nursery/garden fabric covering too. So it will be an eye opener one way or the other with this approach.
Not all no-till planters are the same. Some have a single row of round cutting harrow discs that lightly touch the soil prior to the seeding to the ground. It's the best of both worlds due to soil conditions change each year. Below is the size my machine is capable of using when I lived in TN.
/ No till planters #3
No till is all that's done around our area. Works pretty darn well.
/ No till planters
Where I’m from the soil is a clay and dirt mix usually moist only problems is there’s alot of rocks
/ No till planters #6
On the farm there is a no-till corn planter and a no-till grain drill,
they both work good in most situations, they both can be used in tilled ground if needed.
No till will work in most growing conditions if the ground has not been compacted by heavy hoofed traffic or vehicles.
Spray or burn off (flame weeder) green growing vegitation and then plant
/ No till planters
We usually spray and cut low before we plant
/ No till planters #8
The no till stuff used around here are mostly row crop planters with tripping subsoilers that lead everything, then coulters and then the planters. You can plant in any type of soild. Rocks would present some issues I suspect.
/ No till planters #9
To me that sounds more like strip tillage.
Depending upon what type of ground cover plant is on a field and how much is a deciding factor in our no till programs.
Almost all of our corn fields get rye sowed as a cover crop in the fall, if it's fairly short often it get's roundup'ed
and planted a few days later. If it is later in the spring and the rye is up tall enough to be worth cutting and chopping
as a "haylage" type we will do so then spray the stubble in a week then plant.
Some of the roundup ready corn can be seeded in right after the rye is removed and sprayed later after the corn is up.
But we aren't real fond of the roundup ready seed and it does cost more.
/ No till planters #10
Ah you must live near Columbia, TN or near Machester, TN. I was up near Portland off the I-65. I use a notched disc harrow. One can hear the rocks against the discs. It wasn't too bad with no added weight. In my area, tobacco was the cash crop and smokey barns. Then came the soy, corn and okra. I sure miss that area.
/ No till planters #11
Always just called it no till. Whatever you call it it's planted right over the reminents of the last crop and sprayed with Roundup at some later point. If it's corn the nitrogen is applied with planting and of course fertilizer is bulk spread.
/ No till planters
I live about an hour south from Columbia
/ No till planters #13
Nice, your near the stateline then. I drove down to Decatur, AL and bought my Yanmar YM2610 from Fredrick's down that way. Super nice country down the I-65 and around the I-840, the hills are beautiful too.
/ No till planters #14
Of all the things I wish we did have in my area of SC rocks are not one of them. That area you live in is a beutiful part of the US.
/ No till planters
We actually bought our mahindra roxor from Fredrick’s in decatur
Landhonor 3Pt Potato Harvester (A66285)
Landhonor 3Pt...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
1997 Ford F800 Dump Truck (A62613)
1997 Ford F800...
