Loader Quick Attach leaking
/ Loader Quick Attach leaking #1
DOCatRU
Wallingford, VT
Kioti CK 30 (2008, gear drive, 415 hours)
Hi folks:
This is on a 2008 Kioti CK30 with the KL 130 loader. It is routinely stored in a shed with one side open to the elements.
One of the four quick attach fittings (the white one) is leaking. Hydraulic oil bubbles up in the gap at the top of the slip collar that locks the upper fitting onto the lower one.
1) I have removed the pressure by detaching the relative hoses.
2) Detached the quick attach fitting.
3) Wiped it clean.
4) Reattached the quick fitting.
5) Reattached the hoses.
......and it still leaks.
Do these fittings go bad over time? It is the fitting to the far right in the picture. You can barely see a ribbon of oil above the slip collar.
Your suggestions are greatly appreciated.
regards,
DOC
/ Loader Quick Attach leaking #2
Hi folks:
3) Wiped it clean.
regards,
play tic tac toe
DOCView attachment 744890
You can use two different kinds of pipe joint compound made of Teflon. Tape the threads to prevent them from unraveling. After that, put in some pipe joint compound. Enhance the connection's stability. To ensure a secure seal, lubricate the ferrule of any compression joints, wipe away any pipe joint compound, and align any slip joints with extreme precision.
/ Loader Quick Attach leaking #3
Or maybe just put a new end connector on it.
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
HYDREMA 912HM ARTICULATED DUMP TRUCK (A65056)
HYDREMA 912HM...
CASE TV380 (A67714)
CASE TV380 (A67714)
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
