Lets talk golf carts.
/ Lets talk golf carts. #21
I have owned electric carts since 1998. At one time owned three, a 1998 36 volt EZGO, a 2006 48 volt Club Car, and a 2008 48 volt Club Car Carryall with a dump bed. Use the EZGO and Club Car at the golf course and the Carryall on my 20 acres. I used the Carryall to transport me and my tools to my barn which is 300 yards from the house and general yard maintenance. Batteries on the carts used on golf courses generally last 6-8 years while the Carryall still has the original batteries from 2008. All three have been very dependable vehicles. The Carryall is used for mostly short runs, does not get used everyday and often does not go on the charger for two or three weeks. The golf course cars are often charged two to three times a week. The key to long battery life is to buy quality batteries and proper maintenance. Check batteries regularly and don't overfill. Keep the terminals clean(once a year). The negative for me is ride. Golf courses are mostly smooth if you keep the ball in the fairway. Acceptable ride. My twenty acres has plenty of rough terrain, so ride is harsh.
/ Lets talk golf carts. #22
I have had electric golf carts for over 20 years now. So much more convenient than trying to crank up the 4-wheeler and so much easier to mount and dismount as old age creeps up. Being rather thrifty, I usually advertise on Craigslist that I want to buy a non-working golf cart and get one for about $50 that needs new batteries and usually something else. Sometimes it is as simple as a 50 cent switch, sometimes a broken wire. I started out with EZGos but most of the old ones had too much rust around the batteries so now I only get aluminum Club Cars.
Since my house is over 1/4 mile from my barn they get daily use and I have one for me and one for my wife. Hers is a regular Club Car 10 years old that I got 8 years ago that had been abused and only needed new batteries. I have done nothing else to it since. Mine is a Carryall with a dump bed that is so handy I will never get anything else. It's 20 years old now and has never had a problem worse than a bad wire and I pull a lot with it and have mud tires on it and go places that my old 2 wheel drive 4 wheeler could not go.
My property is over a mile in depth and fairly swampy in back. I put my mud tires on backwards so that it has more traction going backward than forward and that way if I ever drive so far in the swamp that I get stuck, I just put it in reverse and back out. The trick to maintaining the batteries is to put them on the charger at night after you use it. This takes me about 10 seconds. Keep the batteries clean and check water levels often and use rain water to fill them. Keep the terminals clean and tight and use terminal protectorate.
Since they started using gas with ethanol in it I have preferred electric tools over gas in most cases and now only buy non-ethanol gas to use in my generators, chain saws, weed eaters and any other gas powered machinery that I use only occasionally to keep the fuel lines from disintegrating.
/ Lets talk golf carts. #23
I didn't want to screw up the other Edisto thread. I saw in that other thread that golf carts are now under a new set of rules? If you are renting a house, let's say for spring break, can you not bring your own golf cart?
Thanks in advance.
golf carts
/ Lets talk golf carts. #24
We just bought our first golf cart 18 EZGo with lithium batteries. We're told we can leave plugged in for the 8 months we're not at the house. We'll see. šŸ¤žšŸ¼
/ Lets talk golf carts. #25
Thanks in advance.
That sounds like a good topic for a thread on the particular location you're talking about, this threat is pretty much on golf carts in general.
Aaron Z
/ Lets talk golf carts. #26
Golf carts with a box.. I would trade 2 of those gators for 1 good running cart. Club Cars are about the best. I am kicking myself for not buying a new one every year a while back.
/ Lets talk golf carts. #27
I tried to buy a golf cart for a while. After a couple test drives of cheap beaters, I realized a 36V cart was NOT gonna cut it for me. Just so dang slow, especially when headed up hill. I got close to snagging a couple 48V project carts for under $2k, but the sales kept falling through before I got 'em. People are flakes.
Now just a few years later, even a beater 48V cart is over $3k, and nice ones are at least 5. Never mind..... oy.
/ Lets talk golf carts. #28
I tried dozens of golf carts, but most of the golf cart batteries dry after few years of use, so i think i might need to choose the costly golf carts. Anyone here tried Yamaha golf carts? are they durable?
golf push carts
/ Lets talk golf carts. #29
I've had gas golf carts for 25+ years. My second one was a 4 seat club car that I converted the rear seats to a flat bed. I also put on a 6 inch lift kit and 25 inch ATV knobbies. Last spring I sold my 20 year old cart for more than I paid for it and bought an RTV-XG850.
Golf cart Pros:
* barely used any gas, 5 gallons lasted a summer
* capable of towing 1,000 lbs
* I really liked the stop start feature
* lower to the ground and lots of leg room made it easy to get in an out of the seat, ideal for garden work vehicle
* top speed 50kph
* if you do the maintenance they will run forever
Cons:
* limited cargo capacity and no dump box
* two wheel drive only good in up to 6 inches of snow, limited mud
* not good in plowed fields, bumpy ride on rough terrain
* no front brakes
RTV-XG850 Pro
* lots of power for towing, hill climb
* 4WD goes through 12 inches of snow, handles soft mud well, plowed fields, smooth ride
* 4WD High and Low speeds + diff lock, great in deep mud
* large dump box, easy to dump fully loaded
* good onboard storge, racks for tools etc
* high bed height good work bench for chainsaws etc
* very low center of gravity, very stable on hills and bumps, feels glued to the ground
* very fast 70kph, hard acceleration
* built like a tank
* good farm vehicle that doubles as a fun run-about
Cons
* gas guzzler will drink 7 gallons of gas in 80 km (aka 1 week)
* limited leg room, hard to get in and out of machine, bad for frequent in-out of machine
* no start stop, engine always on
* noisier two banger subaru gas engine vs club car
* have to wait 5 seconds after start up before shifting into gear
* high bed level harder to load ie. pitchfork needs to be at shoulder level
* very fast, accelerates hard
Over all I occasionally miss my golf cart as a garden vehicle, the RTV puts a smile on my face until I have to fill the gas tank.
BTW I did want an electric golf cart but changing all the batteries every 3-5 years was a no go for me. Potentially the unit will sit 6 months a year in our long winters.
/ Lets talk golf carts. #30
I have a Yamaha Electric and the 1st set of Batteries lasted 7 years. You have to maintain them just like anything else. Mine is a 48 volt and runs very well. New batteries this year. The only reason they would go dry is if you don't keep distilled water in them.
/ Lets talk golf carts. #31
I have a 2014 EZGO 48V RXV with a flip-style rear seat that converts into a flat platform, bought used via craigslist a few years ago. Previously had a 2007 Yamaha 48v. The EZGO is a DC to AC setup, much faster than the Yamaha.
Biggest problem for me has been keeping expensive batteries well maintained. The two 48v chargers I've had, despite both being digital chargers branded by the cart manufacturer, would overcharge the batteries, boil off water, and shorten the battery life. Tried to be good about not leaving them plugged in too long, but it was a headache keeping up with the water and terminal maintenance.
Recently changed strategies: I mounted a MinnKota four bank charger on the cart. I also changed the dying, expensive, 2017 batteries to a set of Group 29 Everstart Maxx deep cycles. I did this knowing full well the batteries are not the quality of the typical golf cart batteries. But they were less than half the price per battery. The cart is plugged in whenever not in use, and I trust the MinnKota charger to keep each of the batteries properly charged. I've gotten as much as eight years of service out of similar batteries and chargers on a trolling motor setup.
Seven months in, and I am very happy with the results. With zero battery maintenance, the cart never falls below 3/4 charge in our regular use. The terminals remain clean and need no attention. The cart also weighs about 100lbs less with this setup, so it's a bit quicker, especially up hill. If I get 2 to 3 years out of the Everstarts, I will consider it a success.
The cart is used daily on our 62 acres, and does everything from pulling carts and a 4x8 trailer, to hauling hundreds of pounds of garden supplies, chicken feed, cement, building materials, etc. I even use it to pull a log arch with modest sized tree sections. The rear flip seat serves as a work table, sawhorse, and many other things for all of our projects. We take it into the woods (on trails) during deer season. It's a fairly stealthy way to get to a deer stand. And, it's very useful when we have elderly folks like the M-I-L visiting. It's an essential piece of equipment for our lifestyle.
/ Lets talk golf carts. #32
Golf cart Pros:
* top speed 50kph
Cons:
* no front brakes
RTV-XG850 Pro
* built like a tank
Cons
Electric
Pros
It’s quiet
Cons
Who cares? I can actually carry on a conversation 🤫
/ Lets talk golf carts. #33
One more vote for an electric golf cart. Yeah, I do have a SxS as well as a tractor. But for quick 150' walking trips to the workshop, or any other errand, you can't beat a GC.
We're on our 2rd one. Started out with a 1994 in 2010 ($900) and used it until it slap wore out. Bought a 'new' one iin 2013, a 1997 ($2000), that we're still running the wheels off. We don't need a $9K shinny one for our use out here in the country.
No gas needed. Batteries maybe, every 6 or 7 years. Just add water and keep the GC greased. Small price to pay for the utility, not to mention the nice quiet ride on our trails, be it for hauling feed, utility trailer or whatever. We plug ours into the charger when the volt meter gets down to 50%; not so much different than any other vehicle.
My experience with gas golf carts has not been so great, having had to used them for my work in chemical plants. I suspect other users ran them really hard before I was assigned to them but they always seem to break down on me when I needed to go somewhere. Not to say they aren't good - I'm sure they are. They're faster and a bit more powerful than the electric model, but not nearly as dependable for me.
/ Lets talk golf carts. #34
As an update, we did leave our cart with the lithium pack plugged in for 7 months and all is well, no issues.
/ Lets talk golf carts. #35
Like others here, my shop is a quarter mile from the house. It's also up hill with a fairly steep grade. I've looked at golf carts and UTV's to make the twice daily trip but with my limited garage space, storage is an issue. I suppose these vehicles can be stored outside but the weather is sure to take it's toll.
For now, I keep my Kubota L6060 in the garage next to the house and use it to shuttle back and forth to the shop. It uses more fuel than I'd like though and I'm a bit concerned about the frequent stop & start action.
For those who own these carts & UTV's, do you leave them outside and if so, does the weather cause problems?
/ Lets talk golf carts. #36
Buy an old one and watch out for mice
/ Lets talk golf carts. #37
My Yamaha Cart stays inside as does every other expensive toy I own
/ Lets talk golf carts. #38
Same here.
The local golf club stores their fleet of carts outdoors but they replace them every few years.
/ Lets talk golf carts. #39
Golf carts with a box.. I would trade 2 of those gators for 1 good running cart. Club Cars are about the best. I am kicking myself for not buying a new one every year a while back.View attachment 709193View attachment 709194View attachment 709195
That is similar to our first cart , but ours is a 1970 Cushman Golfster with a box.
We got it for free but it needed some work for sure.
11 hp kohler got a new piston ring set ( was burning a LOT of oil) , gaskets, carb, fuel pump, and rear tires. Still needs new fronts and wheel bearings. But for being 52 years old not bad on repairs.
Wife wanted an electric and her dad just upgraded to another new electric (he golfs a lot) So he offered to sell his well used electric ez go? (haven't even looked at it closely) and she bought it.
So far she said she really likes it and I guess the Golfster is mine now :D
Unfortunately for me, she painted it pink before she bought the electric cart. 😱
I think both gas ad electric have advantages over each other.
/ Lets talk golf carts. #40
Do any of you use a golf cart and find it practical? When we built our house 12 years ago there was not room to build my shop right next to the house (past house all I had to do was walk about 30' and that was it) so I had to build it in the back of the lot behind some trees and it is about 150 yds away. At first I didn't mind it too much, making a dozen trips a day back to the house to go to the bathroom, get a drink, answer the phone etc. But now it is getting old and my wife does a lot of flower gardening and does the same. We have a UTV that we use to ride the back co. roads and haul our drinking water from a spring. But a UTV is not practical for yard work when you start and stop every 5 minutes. We have a recycling center about 1/4 mile away and I don't like to get the Kubota out just to do that as it never even gets warmed up. I was thinking about getting a used 48 volt golf cart. Have any of you used them. Don't want a gas, just another motor to work on and maintain.
I'm 52. We are on a large place. Dad has a sxs he uses and we put my momma in the golf cart business years ago. Keep one going for her. If it goofs up we fix. If it's not worth it, we get another one. My brother is close and has 4 wheelers and a cart. Usually the kids are on the golf cart. We have a large pond 3/4 mile behind the house. They all go fishing almost daily. Probably 5 acre pond. Don't turn down a gas one, they are good too. Electric keep good batteries and clean connections. I've chased horses and drug stubborn mules with that golf cart. When I drive up to the house, first I look for golf cart in the shed. If it ain't there, garden next, ain't there, she's at the pond fishing.
CHANDLER 500 BBL FRAC TANK (A60736)
CHANDLER 500 BBL...
2014 Bolens 11A-020W765 20in Push Mower (A60352)
2014 Bolens...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2019 GALYEAN...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
