Stump Grinder options?
/ Stump Grinder options? #1
BoneDigger
Tyler, TX
2015 New Holland Workmast 35
I just had some land thinned. I have about 350 stumps I want to grind down, but I'm in no huge hurry. If I wanted to buy a grinder for let's say under $5,000, what would you recommend. Hiring a grinder is too expensive. I could rent one but would prefer to have one available as needed. These are mostly pines (95 percent) and between 12 and 24 inches, with a few larger ones. I saw where there are pto attached options but it seems a hassle using the tractor. I would think walk behind would be better?
Thoughts?
/ Stump Grinder options? #2
Thoughts?
Went thru the SAME exact issue you had, but with 3,000 stumps. We negotiated with a logger who owned a stump grinding machine that looked like a rhino on 4 wheels. It was quick. Cost was nearly $1 per stump. $3,500 to do them all. He said because the stump were all in lined rows, grinding would be quick and simple.
Stump Grinding Drums are very fast.
Here's a Tractor 3PT 24-inch stump grinder drum.
Machines that do this by swing side-to-side take FOREVER.
Inverter (A61166)
Inverter (A61166)
2022 Jeep Grand Cherokee 4x4 SUV (A61569)
2022 Jeep Grand...
2020 Case IH 475 Speed Disk (A63109)
2020 Case IH 475...
2021 BOBCAT E32I EXCAVATOR (A62129)
2021 BOBCAT E32I...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
New/Unused Landhonor Mini Skid Steer Pallet Forks (A61166)
New/Unused...
