Bucket level indicator
/ Bucket level indicator #1
Mtsoxfan
Newark Vermont
Kioti 3520SEH Holland TC29D
I have a New Holland TC29D. My loader has the level indicator tube, but nothing attached to bucket. Does anyone have a similar model that can post a picture of setup?
Thanks...
/ Bucket level indicator #2
Parts breakdown of the 15LA loader but doesn't show a bucket level indicator.
Edit: Same thing for the 14LA:
I had a TC29DA at one time but the loader was SSQA. Don't recall whether or not it had a bucket level indicator. P.S. Someone will come along and say you don't need a bucket level indicator. Pay no attention. :)
on my Yanmar, I knew the bucket level without using an indicator. Just cant seem to get the NH right.
/ Bucket level indicator #4
Not sure about NH but if you have a tube, a lot of these will have a rod that slips inside and is adjustable so that it's either flush with the tube or something else do distinguish level.
Pictures are a kubota version.
A little studying of what you have and you should come up with something.
/ Bucket level indicator #5
Quite a few threads on bucket level indicators....
Search feature using "bucket level indicator" will reveal many more...
Thanks. The indicator you made looks impressive. Since I have the factory tube, I was just looking for how to hook up a rod. I'll try to figure something out, maybe a NH owner will post a picture before I do...
/ Bucket level indicator #8
Thanks...
Mine on my TC45 looks like in this video.
/ Bucket level indicator #9
I sold the tractor but these are the best pics I have. I think the rod went down and fastened into a hole in the bucket just above the cylinder pin.
/ Bucket level indicator #10
Rod just needs to be a few (2-5) inches above pin so as bucket rotates around pin, the rod connecting point rotates in a arc to push/pull rod up/down in tube....Just make sure rod is long enough it does not pull out of tube when bucket is in full downward rotation...
Thanks for the video, pics and tips. I'll look for a mounting hole/braket again. I just found a 7308 loader (like I have) picture that shows the indicator rod. I'm sure I can create one using that picture.
Thanks for the help.
/ Bucket level indicator #13
Yeah, and you have a flat top on bucket. Mine is rounded, so no help there.
After cleaning dried mud out of indicator rod mounting hole, I measured from hole to top of tube when bucket is maxed out. Added 1" for 90* ange that mounts into hole. Figure I will add 2" to stick out of tube. 40" should do it...
/ Bucket level indicator #16
And it works at any height. Need the bucket level as you slide something out of a pickup bed onto forks that you cannot see? This works well.
Only works with bucket forks.
Not SSQA forks
But it is only accurate when it is on ground level. Things change as you raise...
/ Bucket level indicator #18
This might work. Easy to make. Used some 3/4 inch PVC, two plugs, elbow. Eye bolt on FEL Some tape to mark the level point. Screw clamp to attach to back side of loader. I've now added a zip tie, too.
