Bush Hog
/ Bush Hog #1
Bentrim
Gold Member
York County, Pennsylvania
Massey Ferguson 245, Massey Ferguson 14 Allis Chalmers G
I know I'm being picky but I have an issue with folks calling a rotary mower a Bush Hog. Bush Hog is a brand name just as John Deere, Ford, Dodge, etc.
Home - Bush Hog This is the Bush Hog website note they even call them rotary cutters. I know it may be a hard habit to break but could we learn to call them rotary cutters unless of course you are referring to the Bush Hog brand.
/ Bush Hog #4
I would agree, you are being picky
/ Bush Hog #6
You mean like "Band-Aid", "Kleenex", & many other brand names that are used by millions of people EVERY DAY?
I can't think of a better compliment for a brand.
I'm sure Bush hog doesn't mind.
/ Bush Hog #9
Around here he even spelled it wrong. It’s a BRUSH HOG.
Gooseneck trailers, heliarc so many things are known by the name of the original company that invented or introduced them to the world.
/ Bush Hog #10
Bush Hog is out!
How about:
Brush Hog
rotary mower
rotary cutter
shredder
rough cut mower
pasture mower
field mower
pasture cutter
hay cutter
I am sure there are more.
/ Bush Hog #11
Bush Hog is out!
How about:
Brush Hog
rotary mower
rotary cutter
shredder
rough cut mower
pasture mower
field mower
pasture cutter
hay cutter
Don't all of those also apply to my finish mower?
Well.... All except Brush Hog, everybody knows what those are.
/ Bush Hog #12
No one cares what you call them
I do, and if you ever noticed, I call them what they are, rotary cutters. I have three rotary cutters and I'll throw it out right here, the BEST rotary cutter I've ever owned or used is the Woods 720X Brush Bull that I now own.
SR
/ Bush Hog #13
SR
I would have thought your sawmill was your favorite "rotary cutter".
/ Bush Hog #14
What is a Rotary Cutter?​
A Rotary Cutter is a cutting tool for fabrics. It is a sharp blade wheel, in a handle, used to slice through multiple layers of fabric and resembles a pizza cutter. Rotary Cutters also come in a variety of blade sizes, commonly 18mm, 28mm, 45mm and 60mm. The larger the blade size the more layers of fabric or thicker fabric you can cut. The smaller blade size allows more manueverability.
The blade of a Rotary Cutter is secured in a handle for safety. There are a variety of handle styles available, some designed ergonomically for those with physical issues like arthritis.
There is a protection mechanism to prevent the blade from being exposed unintentionally. Safety in using a Rotary Cutter is critical - always close the blade after each use and when not in use.
I use mine for Leather
1500 Gal Stainless Steel Tank (A64127)
1500 Gal Stainless...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
2023 Bobcat T86 (A64126)
2023 Bobcat T86...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
