New Woods tiller problem.....
/ New Woods tiller problem..... #1
1734e
Massey Ferguson 1734E
I'm very new to tractors and very mechanically dumb. Got me a 2019 Massey 1734E last summer with only 40 hrs on it, and not long after that I bought a new Woods RT60.40 5 ft reverse tine tiller for it. I didn't have a chance to put it on until a week or so ago with a neighbors help. He knows a little bit about tractors but wasn't sure how to measure the pto shaft so he helped get me get the tiller on and left me to decide what to do about measuring the pto shaft....I watched a few videos on youtube and decided to follow a video that showed measuring from groove to groove on tiller and tractor shafts making sure they were level with each other before measuring, took it to a hydraulics and tractor service shop down the rd and he cut it according to my measurements. Next day my neighbor came over to help finish attaching the shaft, leveling tiller and checking fluids. The shaft connected fine and everything seemed fine according to him and we started it up. On his advice i engaged pto with engine at idle and he said not to run it at a full 540 just start at idle and after engaged run it slow some above idle and not at 540. I was confused by this because what I was seeing in manual said run it at 540. So after I'm on my own with it I decide maybe he was just wrong and should run it at 540....I go about doing my first tilling ever and mistakenly doing so without reading through my manual which caused me to make some major mistakes. Some things I have learned after now reading the manual and watching some more videos is that 1 according to manual ....it being a new tiller and first run with it I should have done a clutch run in/slip clutch adjustment (still dont really know what that is or how to do it even after reading how to) 2 I started using it by getting tractor up to 540 ...tiller all the way up and engaging the pto too fast then lowering it into dirt. when done with a row I raised tiller all the way up still running until i got setup to do same on next row. I done about 4 35 ft rows like that on one garden and then took it to another garden and got a 50 ft row done and thats when i started hearing a clanking noise seeming to come from the top gear box. I shut it off and brought tractor back up to the house. The tines still turn and there isn't any hard vibrations or anything coming from tiller just the clanking noise. Guess I'm going to learn the hard way to read manuals and know a little more about what im doing seeing how its a pretty expensive fix to be making stupid mistakes and not taking time to know what im doing. My question is did I shear a pin or mess up something in the gear box or other? What's my next step? I'm sure from my faulty operation I've probably voided my warranty. Any help or suggestions would be appreciated.
/ New Woods tiller problem..... #2
I had a woods brand tiller for over 20 years and always ran it at 540 RPMs. Pto operated implements are designed to run at 540. It is probably a good idea to engage the implement at a lower RPM, then increase to 540 as you start working the implement. That said, I usually didn’t follow my own advice and did engage the implement at 540. Never had a problem with the tiller and I just sold it to my neighbor still working fine. Yes, you are supposed to slip and adjust the slip clutch annually, but I did this infrequently. I doubt that you did anything to damage the tiller. I would ask your dealer to turn in a warranty claim on the tiller. Or perhaps the clanking is something simple. Is the driveline cover chain banging on the gearbox or is the clanking internal? The slip clutch should protect the gearbox from damage in normal operations.
Thanks for replying.....I will have to check on the chain banging, and will check again if there is anything else that could be causing the clanking..loose tines or obstructions. It was operating fine at first no clanking just started to after around 40 minutes of tilling. I will make sure after I get to using it again that I will engage at a lower rpm then increase to 540. Thanks again
/ New Woods tiller problem..... #4
One loose time can sound like the hound of hell are inside tiller.i know that for a fact on my woods 4ft unit.
Luckily 5 year gearbox warranty.
/ New Woods tiller problem..... #6
After several successful years use of my tiller, I had the "clanking" noise just recently. It functioned...tilled just fine. After finishing, I looked the attachment all over. Turns out that the plastic safety cover had come loose on one end. The inside was mangled. It looks like I'll have to buy somenew parts for the shield, a whole new shield or just leave the darn thing off.
Cheers,
Mike
/ New Woods tiller problem..... #7
Is that clanking all the time or just when the unit is raised high ? Most if not all 3pt implements can create a fairly loud clanking noise if you raise the 3pt hitch too high while running. This causes the U-joints in the driveline to be at an extreme (greater) angle and they make a noise. Try lowering the tiller to just above the ground and run it at the std 540 rpm. If it still clanks then you have something loose to be investigated.
/ New Woods tiller problem..... #8
Also, did you grease the U-joints? Do you feel any slop (if you turn the shaft by hand with the tractor off does it rattle or skip)?
/ New Woods tiller problem..... #9
just gonna reiterate this.
make your dealer look it at.
/ New Woods tiller problem..... #10
Does the clanking noise sound in sync with the RPM, for example if you slow the engine down does the sound slow down too? Can you isolate the sound to just the top gearbox, or could it possibly the the top ujoint on the PTO shaft? Roughly what is the angle of the shaft? Had a horrible sound coming from another implement and it turned out to be the ujoint.
Following, I am fairly new to tilling myself but haven't had anything like that yet
/ New Woods tiller problem..... #11
Sure, understand your point. But if the clanking is only when he has the implement in the extreme "up" position then there is nothing wrong and no reason to have anybody look at it.
/ New Woods tiller problem..... #12
and after 6 hours of use my brand new tiller had NEW noises when raised and needed gear adjustment PER woods, dealer fixed it. secondary noise was one loose tine (only heard when tines in ground) but dealer had tiller for a week and 10+ hours of calls with woods reps (including pics of internal gears sent, etc) due to a noise only when raised up.
so yeah. we pay for the warranty, use it.
backlash adjustment reset and warranty on that section reset.
edit: I should mention I also had noise when deep INTO dirt but...the loose tine offset that noise.
snap noise not the same as the high angle of attack thud noise.
Thanks to everyone that commented. I finally got out there to give it a good looking over keeping in mind the comments of this post and found that I have 2 tines on same plate that are loose. Not sure why that would happen the soil i was in was pretty soft. Can't find much on the fix for this. Is this something easy to fix or will I need to take to dealer to fix. The way they are loose I don't understand. The bolts seem intact. When I moved them I noticed there is another hole in the top tine plus (Im assuming) another hole that the bolts is in.
I did not grease the u joints but i will be now to make sure they are greased. thanks for commenting
/ New Woods tiller problem..... #15
Bolts that aren't torqued properly loosen, bolts that are over tightened, sometimes stretch. (read loosen)
I never reuse tine bolts, I always use new QUALITY bolts, every time.
SR
SR
Here is a picture of the tine. Do you think its just gotten loose and needs tightened up? or is there something broken? The bolt doesnt seem broke, and why is there the extra hole? ... Its only been used for about 40 minutes...thanks
/ New Woods tiller problem..... #18
Sawyer is right. Look at the tines that are not loose and see how they are connected, With only one bolt those tines will be swinging and banging like crazy . You did not say whether you had filled the gear box and side box with fluid.
Yes I checked the gear boxes and they were full I will check the tines that are not loose and compare.
I checked and there is only 1 bolt per tine, so im a little confused esp as there is that extra hole which im guessing is for using for different positioning or rotation of the times....
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
