Broke 2 Oil filter wrenches
/ Broke 2 Oil filter wrenches #21
My theory is they all employ a team of gorillas to put the filters on at the factory.
I used a pair of channel lock filter pliers on mine, looked like it had been in war after it came off!
/ Broke 2 Oil filter wrenches #22
The filters guy at the factory‘s name is Ivan, his arms are the size of most guys thighs, and they give him a 4 foot breaker bar to put the filters on.
Had a buddy who drove a screwdriver through the filter, it didn’t work, the filter just shredded. He also ended up using a chisel to get it started turning and got it off.
The second post by Indyjay is probably the best filter wrench I have but you can’t always get it in places. I’ve also got a very large set of channel locks that work if there’s room. Like everyone else I’ve had a few I used some very foul language on. It must always work because the eventually came off.
/ Broke 2 Oil filter wrenches #23
I know the feeling....sounds like we all do. I've got a drawer full of oil filter wrenches now. Including a set of cannister sockets, a gearwrench, and a 3 jaw. Back when I was doing mechanics for a living I only had on a strap wrench. What changed? I have no idea.
<snip>
I don't know how long it's been since you were a mechanic but things that have changed:
Small cars have engine compartments that pack a lot more stuff in. And often the manufacturers design for the home market.
My meathooks can't even get to some replaceable parts of my vehicles (like headlight bulbs) , whereas my 5' tall wife can easily access the item.
I had a '79 VW Rabbit that to change the oil filter I could kneel down in front of it, reach up behind the radiator with a 3-Jaw Oil Filter Wrench and undo the filter. EZPZ. The filter was pointed down with easy access.
On the 2019 Ford Escape the filter for the 2.0 liter Ecoboost is oriented about the same. The smaller engines have it mounted horizontal amongst a bunch of hoses, and looks like a royal pain o service.
/ Broke 2 Oil filter wrenches #24
Screwdriver works great as well.
One with a long handle for leverage. I believe every new tractor owner has that to deal with on the first filter change. Seems to be common practice (painting the engine and transmission after the filters have been installed( and the enamel dries and locks the filters onto the filter bases. Had that issue with fuel filters as well.
Actually, my SOP on a filter change anytime on a tractor is the poke a hole in it and lever it off (so long as the space is adequate to do it), I'm changing it anyway and have the drain pan (or in my case a partial aluminum fuel tank under there anyway) Both my tractors hold almost 15 gallons of fluid in the gearbox and rear end assemblies, substantially more than an ordinary drain pan can hold. I'll use a conventional drain pan for the engine oil, but that's it.
Always get a kick out of pulling the gearbox drain plug(s) and observing the fluid coming out. Reminds me of an oil well. Least with me, disposal isn't an issue as I have a Kleen Burn waste oil furnace in the shop. In fact I can run out of waste oil to burn in the winter so I hit up the local discount auto parts stores for their 'collected' waste oil if I need it.
/ Broke 2 Oil filter wrenches #25
Before the 1970s or so, cars were designed to be serviced by the owner. My ‘49 Ford, every thing was easy to get to. Some cars today, you have to unbolt the engine mounts to change the spark plugs.
/ Broke 2 Oil filter wrenches #26
My CUT filter is in very close quarters.
After rejected my collection of filter tools I resorted to a DIY method.
I use a short length of seat belt material and a pair of vice grips.
Wrap the seat belt around the filter can and grip the belt close and lever with vice grips using the fat side to lever tighten the belt as I rotate.
Works great.
LOL, then catch the mess.
The belt barely clears as I slip it onto the can as the clearance is that tight.
/ Broke 2 Oil filter wrenches #27
Oil filter? None at all on the '55 Chev 265ci, the first SBC. An external one like in the Ford photo was optional.
The external ones were an awful mess to take out the element, wipe remaining oil out of the cannister, dispose of the filter element. Dad's '49 Chev aftermarket filter used a roll of toilet paper as its element. Messy!
Cars were simpler then.
/ Broke 2 Oil filter wrenches #28
My first oil change on the Kubota - both engine & hydraulic. Long, thin bladed kitchen knife. Cut the "paint bond" between the filter and the tractor. Removal was much easier. They all came off easily with a band wrench.
My idiot ex wife wanted a Saab. She thought they looked cool. It drove all right, could go like a bat out of hell.
I had to do the water pump.
To access the water pump, required I drop the tranny and lift the engine. Yah, for the water pump.
It would only accept one model of Continental tires ( the most expensive model).
I got rid of that car with the witch.
pressure washer, and trailer (A56859)
pressure washer...
Brent 420 Grain Cart (A61307)
Brent 420 Grain...
2014 VOLVO VNL (A60736)
2014 VOLVO VNL...
2002 WACKER RD25 ROLLER (A59906)
2002 WACKER RD25...
Pallet fork mount safety basket (A61567)
Pallet fork mount...
2023 FORD F-650 SUPER DUTY CAB & CHASSIS TRUCK (A59823)
2023 FORD F-650...
