Mahindra 4500 issues starting on again
/ Mahindra 4500 issues starting on again #1
PerezVic_08
Mahindra 4500
Hello everyone, I have a mahindra 4500 series tractor. I recently replaced the clutch and was able to move it to put back on the front loader but was now having issues with it starting over already checked fuel lines, fuses, wires and no luck, it cranks but no start.. HELP!
/ Mahindra 4500 issues starting on again #2
Check for fuel flow to the injector pump (IP). open the line that feeds the IP and you should have a STEADY gush of fuel. If it dribbles or is intermittent work your way through all of the components (lift pump, fuel lines, filter, filter head, tank valve tank outlet screen, etc) until you find the restriction. If you have one, make sure that the fuel solenoid that is actuated by the key switch is opening when you try to start.
If you have a common rail system, check all the connectors as well.
I just checked it out and diesel only passes thru 1 injector also I think the manual fuel pump Is not working properly because it not getting pressure
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
2019 John Deere R-4038 (A61306)
2019 John Deere...
Volvo VNM (A63689)
Volvo VNM (A63689)
Used Landpride GR1525 Stump Grinder
Used Landpride...
