Mahindra 4500 issues starting on again
/ Mahindra 4500 issues starting on again #1
PerezVic_08
Mahindra 4500
Hello everyone, I have a mahindra 4500 series tractor. I recently replaced the clutch and was able to move it to put back on the front loader but was now having issues with it starting over already checked fuel lines, fuses, wires and no luck, it cranks but no start.. HELP!
/ Mahindra 4500 issues starting on again #2
Check for fuel flow to the injector pump (IP). open the line that feeds the IP and you should have a STEADY gush of fuel. If it dribbles or is intermittent work your way through all of the components (lift pump, fuel lines, filter, filter head, tank valve tank outlet screen, etc) until you find the restriction. If you have one, make sure that the fuel solenoid that is actuated by the key switch is opening when you try to start.
If you have a common rail system, check all the connectors as well.
I just checked it out and diesel only passes thru 1 injector also I think the manual fuel pump Is not working properly because it not getting pressure
Drag Tank, Fill Rite 15GPM PUMP  (A62679)
Drag Tank, Fill...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
Stihl MS 362C Chainsaw (A62613)
Stihl MS 362C...
