Mahindra 4500 issues starting on again
   / Mahindra 4500 issues starting on again #1
PerezVic_08
Mahindra 4500
Hello everyone, I have a mahindra 4500 series tractor. I recently replaced the clutch and was able to move it to put back on the front loader but was now having issues with it starting over already checked fuel lines, fuses, wires and no luck, it cranks but no start.. HELP!
   / Mahindra 4500 issues starting on again #2
Check for fuel flow to the injector pump (IP). open the line that feeds the IP and you should have a STEADY gush of fuel. If it dribbles or is intermittent work your way through all of the components (lift pump, fuel lines, filter, filter head, tank valve tank outlet screen, etc) until you find the restriction. If you have one, make sure that the fuel solenoid that is actuated by the key switch is opening when you try to start.
If you have a common rail system, check all the connectors as well.
I just checked it out and diesel only passes thru 1 injector also I think the manual fuel pump Is not working properly because it not getting pressure
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2015 GMC Acadia SLT1 SUV (A50324)
2015 GMC Acadia...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
2008 BMW 528i Sedan (A50324)
2008 BMW 528i...
