Adding 4wd to YM2310
/ Adding 4wd to YM2310 #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
If I found a junk YM2310D that had a good 4WD assembly, would it be a nightmare to add to my 2310? I suspect it would because I would need to change major transmission assembly components. Maybe better to find a 2310D with a bad engine and just put the engine from my 2310 into it. I only consider this because I keep getting my 2310 stuck, even with the weight of the 4 foot box blade. More weight will help for sure. As will drier ground. But I can't justify the cost of a good 2310D.
Thanks,
Eric
/ Adding 4wd to YM2310 #2
I am not sure but I think you would have to take off the present cover and replace it with a complete drop box assembly that you will see on list 47 of the 2310 parts manual. You would also need a driveshaft and cover. The hard part would be adding the front drive gear that goes on the rear pinion shaft. Overall, a major undertaking. 4 wheel drive is a wonderful thing! (y)
/ Adding 4wd to YM2310 #3
Does the 4x4 version even have the same final drive gear ratio as the 2x4? And tire size?
Sounds like you would need the entire transmission assembly, complete, from the donor tractor as well as the visible 4x4 components. That's a major project.
/ Adding 4wd to YM2310 #4
Why do you want 4wd? If it's just for the fun of doing it then that makes sense to me. But if the reason is for more traction there are other ways.
I want 4WD just for the traction. I have weight in the rear and am going to add more weight to the tires. Maybe I could add chains. Maybe new tires too. I don't care about any kind of cool factor, I just get tired of spinning tires on gentle slopes. And getting stuck when the front tires have to go over a bump.
Eric
Yeah, I'm thinking, after looking at some pictures, that if I want 4WD I need to get a tractor that already has it.
Eric
/ Adding 4wd to YM2310 #8
But what you could do becasue it is 2wd it is easy to fit some wider wheels with industrial tires and wheel weights. I did that and it works.
/ Adding 4wd to YM2310 #9
Eric
In our coastal climates (freaking wet) I'm sure you deal with the same traction that always seems to be right on the edge regardless, even with 4WD just now trying to move a bucket load of fill dirt up a gentle slope.
/ Adding 4wd to YM2310 #10
At some point, you just need to change tools...
I was out on a slope today trying to consolidate some soils, and between the slope and the soil conditions just couldn't get it done. Very annoying, but I didn't roll the tractor, and I want to keep it that way. Renting a dozer isn't in the cards at the moment, so this project will just have to wait for a bit, as annoying as that is.
It seems like there is always something that "if I had a..., I could do that." Personally, I have learned for me, if I let the problem stew for awhile, I can often find advice on how to do it differently with what I have, but not always.
@etpm I have no idea what the best call is, but I think trying to donor build/hack/switch your way into 4WD sounds to me like it might be the hard way, but I have never attempted it myself.
All the best,
Peter
/ Adding 4wd to YM2310 #11
I hear you on slippery slopes. There just isn't an answer to using a FEL with 2wd on much of a slope.
The reason is simply that all the weight is out front which lifts the rear wheels ....turning poor traction into no traction.
I went to wide tires and ran chains all the time. Eventually I made up a set of really good fitting automotive chains that fit like skins on wider rear tires and that helped some. A friend of mine went one step farther on his heavy Massey 2wd. His Massey didn't have power steering so a FEL would have been pointless even if he had been able to find a subframe for his tractor and then find a front end loader to fit that, beefed up the hydraulics. etc.
So instead of all that and still ending up with an FEL on a 2wd, he put a reversible dirt scoop on the 3pt. That put the weight over the driving wheels, lightened the steering, and he got by for 20 years. I used to kid him that his solution was just good enough to keep him from ever getting a decent 4wd tractor with loader.
Back in the day when all tractors were 2wd, it was rare to see a Front End Loader on any tractor. What you are experiencing is probably why loaders never got popular back then. In fact, a lot of tractors up until fairly recently didn't even have the necessary frames for mounting loaders. Most tractors were a connected series of castings from front to back. The axle pivoted on the front of the engine casting and the rear axles stuck out the sides of the aftermost casting.....with a cast bell housing bolted to a cast transmission inbetween. So not only was there no loader, there wasn't even a place to mount one. The solution to that was to buy an aftermarket steel sub-frame to connect the front and back of the tractor together. Those subframes were specific to each tractor.
A 3pt reversible dirt scoop isn't such a bad solution.
rScotty
/ Adding 4wd to YM2310 #12
A 3pt reversible dirt scoop isn't such a bad solution. View attachment 738681
rScotty
Even a 3PT REL is a good option too. It behaves like a FEL, but in the back. A bit more ability than a pond scoop. Each has their strengths.
A 3PT REL has a strong advantage, the bucket comes off/on easily.
With a hydraulic top-link, variable dumping tilt can be had.
/ Adding 4wd to YM2310 #13
rScotty
I have the same Rear scoop. Use it on the 2wd YM2000 and never cared to have a FEL. since. Many Hrs. on the JD. with one and not having the loader up front while mowing is the biggest plus or using any rear implement for that matter. Besides a few hundred dollars new to a few Thousand. Had it a while.............. Extra set of pins added is well worth it for easy reversing.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A65563)
2021 Big Tex...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
2015 MGS GODWIN CD150M PORTABLE DRI-PRIME (A63276)
2015 MGS GODWIN...
