Feeling
/ Feeling #21
Just curious how you guys refuel your tractors. Do to several shoulder injuries I can no longer hold up a 5 gal can to fill mine.
Diesel I assume. I bought a small 12 v transfer pump. Not a good idea for a gas engine though,
/ Feeling #22
Forty years and I've NEVER had water in the tractor fuel tank. I don't know about my four Jerry cans. The last little bit is never dumped into the tractor. I have a separate five gallon plastic jug where the "last bit" goes. When it's half full I run the contents thru a water separation funnel. After that separation - I will use it also.
A pump of some kind would be great. However, most that I see will draw diesel off the bottom of the tank. Down where any water might be. What I need is a pump with a floating intake or an intake that can be adjusted. So the intake can be an inch or so off the bottom of the Jerry can.
Like most of us folks here on TBN - there are enough problems/concerns without adding "water in the diesel" to the list.
I just use the Mr Funnel to fuel the tractor, then pour the remains from the funnel into a can that I use for brush pile burning. Presumably the funnel remnants contain fuel with water and other contaminants.
/ Feeling #23
I have 2 36 gallon transfer tanks with pumps (1 for gas, the other for diesel) on a small trailer. They don't take up room in the truck bed and all I need to do is hook up the trailer and pull it to the gas station when I need to refill them. I got the transfer tanks on Market place for about $100 each and the trailer for $150. This works great for me. I got really tired of handling fuel cans for tractor, 4 wheelers, mowers, and other assorted engines.
/ Feeling #24
Great idea.
/ Feeling #25
I fill this barrel a couple of times a year. I has a air driven "pump" (it just pressurizes the barrel). 12 GPM Air Operated Barrel Pump
/ Feeling #26
I use an IBC tote (275 gal) with a 12v pump that uses a small gell pack (like you find in an emergency light) that is charged by a small solar cell. All in, the entire system including IBC, pump, fittings, filter, solar panel, etc ~$350 - pump w/hoses & nozzle was $275 on sale. The IBC fits nicely in the back of my pickup. Best part, IBC's around here run $25-40 a piece. Filled it up before all the craziness in fuel prices, added biocide treatment and this "should" last me through the summer/fall.
Really easy to get on & off truck w/forks.
/ Feeling #27
For my 90 HP JD, I have always had a 500 gal above ground diesel tank. I use a hand pump, but you could also get a 12v pump. When the tank is full, I add 2 bottles [16 fl oz each] of "HOT 4 in 1" to deal with any water issues. I get that from my heating oil/diesel distributor, but it's made by FPPF Chemical Co in Buffalo, NY, part #00161. If you have a quality diesel without a lot of contaminants already, you could get by with only 1 bottle or just use periodically. For my JD lawn tractor using gas, I still use 5 gal Jerry's with no problem and I'm almost 70. :)
/ Feeling #28
Use a 55 gallon drum with hand pump in the drum. It also has an inline fuel filter. I built a small enclosure for the drum and I have a lift strap on the drum and use the loader to put it in the truck when need to get fuel.
/ Feeling #29
Harbor Freight (in-store only) for $12 currently. I have used this for a couple of years to fill zero turn, and Ranger from 5 gal cans.
/ Feeling #30
We put our diesel in 55 gallon drums and use a Harbor Freight hand crank pump to fill the tractor. We had to add a hose long enough to get from spout to tractor, but that wasn't a big deal.
/ Feeling #31
You are going to be inundated with replies on this topic because it is so universal and so common to many of us. I will throw in my solution/comments here:
1) It depends so much on your circumstance/environment as well as how much fuel you use per year.
2) Many are saying "transfer pump" and I think that is your best solution hastening to say there are MANY ways to do that. I use a 12v transfer pump (readily available via Amazon) which allows you to pump from a larger tank or even from a 5 gal can if you want. That can get tedious and awkward at times with multiple hoses and electric cords, etc. Not enough hands. My adaptation is to use a 35 gal pesticide tank ($99 at TSC) which I converted to diesel fuel using neoprene gaskets to replace the water gaskets. My 35 gal tank has an outlet that I can use gravity feed if desired but mostly use the pump. Gravity is slower than slow.
3) The 35 gal tank is just right for my once a month farming. I added handles to the top of it and it is easily transported in the back of the old farm station wagon OR in the pickup truck. Very light empty and no need to move it when full.
4) I find the 12v pump is very handy because you can run it off any nearby battery AND you can run it off of a battery charger where 120v is more readily accessible using clip leads. I forget the specs but it moves fuel very fast.
/ Feeling #33
Years ago bought a 100 gallon "L" shaped tank. The one that goes in a truck bed with the crossbed tool box over it.
Converted it to portable. 2, 4x4 skids on bottom. Use forks to place on a trailer. Go to town and fill. Bring it back home and place it under shed. Has a 12 volt pump that I clip to tractor battery.
CT
/ Feeling #34
55 gallon drums on a wheeled dolly from harbor freight. 12volt fuel pump from tractor supply 20 years ago. I tried a few hand pumps, forget it. I have 2 barrels that a fuel truck will come fill with off road, or if I only need to fill 1 of them, I load it in the back of the truck and take it in.
/ Feeling #35
I have a Kubota L6060. There are a lot of reasons why I bought it, but one reason is because it is easy to fuel up with 5 gal jugs. The filler tube is about 1 foot higher than the floor of the cab. I put a plastic milk crate on the floor next to the filler tube, put a 5 gal jug on top, tilt it over, the spout drops right into the filler tube. After I put in 15 gal or so, I go to the bank and take a loan out on my house to refill the jugs with diesel.
/ Feeling #37
And I just stopped filling the can all the way up, but looks like I’ll be using one of y’all’s ideas!
/ Feeling #39
Side question- is that a solar powered security cam I spy? Details?
Amazon purchase..been up for a few years..Gonna replace them soon with arlo cameras for better quality pics.
/ Feeling #40
My day is soon approaching. I can still lift a full "5" but can only hold it there for so long. I'm thinking some form of tipping cradle that can be lifted by a rope hoist. OR some form of foot pump hydraulic lifting/tipping cradle.
Yeah, those 5G cans seem to get heavier every year! What I still do is hoist it up onto the hood, then tilt it into a funnel for the first 2-3 gallons, then lift it up & pour for the rest. I replaced the stupid safety spout with a plain one so no need to keep pressure on it for flow.
New/Unused Landhonor 72in Rock Grapple (A61166)
New/Unused...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2025 Swict 66in. Bucket Skid Steer Attachment (A61567)
2025 Swict 66in...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
