Alternative 3rd function?
/ Alternative 3rd function? #1
LS Tractor Owner
Super Member
Edgewood, NM
LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500
Hi all, I have been thinking about a third function for my loader, but don't really want to spend the $$$ for the electronic 'button' type. Is there any reason why an open center single valve couldn't be plumbed into the power beyond port then continue on to the rest of the system?
I was originally thinking of using one set of rear remotes, but that lever is next to and just below the seat. My loader control is on the loader frame. I was thinking having another lever up by the loader control would be easier to use / operate.
What are your thoughts? Pros? Cons?
/ Alternative 3rd function? #2
Sure. It will work, it has been done before. Some people even managed to mount that valve on a good location that doesn't take much effort moving the hand from the joystick to the lever.
Pros: You get the ability to feather the cylinders, instead of On/off like the solenoid valve setup
Cons: Just the fact that you need to move the hand from the joystick to the lever on the new valve instead of simply pressing a button but it's that big of a deal to be honest.
Don't forget to get the right PB sleeve/fitting for the new valve, so you can feed the rest of the hydraulic system properly. The Tank port will Tee together with the other tank port on the loader valve.
EDIT: Post #2 on this thread: W.R. Long vs DIY 3rd function? is a good example. I've seen a little better installations on TBN though but that's still a nice one.
Other people have also replaced the entire loader valve with a new valve block with 3 spools instead of two but that's a bit more costly.
/ Alternative 3rd function? #3
It's basically what I did, I mounted not a single spool but a 3 spool valve (other two are top-N-tilt hydraulics), as for the having to reach for another lever. It doesn't slow me down and cost wise it was very light on my budget. If pressing a very expensive button is your thing, no problem. I like to keep my money in the bank.
/ Alternative 3rd function? #8
The electric type valves add little to the cost.
Most of the electric type valves have pressure rated tank ports....so no PB. Which is one fewer hose to worry about hooking up....and all the associated fittings and adapters which add $$$.
IMO, the ONLY benefit to a manual valve is the ability to feather the control. But mounting options are limited to still put it in an ergonomic location without getting real creative. Whereas an electric type can be mounted anywhere because you only have a button on the joystick.
A diverter IMO is the best of both worlds as you have the button on the joystick and ergonomics associated with that....but still have the ability to feather the control.
But some people insist a 3rd is better because they dont what to loose ability to control a loader function when trying to open or close the grapple. For me...I have never had an issue where I though...."man I wish I had a 3rd instead of a diverter"
/ Alternative 3rd function? #9
I agree with everything LD1 said.... especially the above ^^^ For our purpose I could never see where a true 3rd function would be needed nor would I want to have an additional lever to control our grapple or the tree post puller. Just push the button & never need to move your hand from the loader valve lever. And it was much less than doing a true 3rd function.
/ Alternative 3rd function? #10
@dlctg that's a slick looking joystick handle with all those buttons. Did that come with the tractor or is it aftermarket?
Many 3rd functions use an electronic valve and two loader joystick buttons, one for each direction. The valve is usually priced a little cheaper than a diverter valve but depending on the install details the hoses may cost a bit more. A replacement joystick handle with two buttons instead of one might cost a little more as well. But they're roughly the same cost if you DIY or use the kit from Summit.
I'm still using a rear remote whose handle is close to the loader joystick. While this set up can feather I don't do it. I keep it on until the grapple lids stop moving.
/ Alternative 3rd function? #11
@ericm979 - I only added the momentary switch for the 3rd function diverter valve. The other two are the HI / LO speed selector buttons for the HST.
We use the feathering feature all the time, especially with the tree / post puller (it will cut smaller saplings in half if it is closed to hard). Also it is nice to use on the grapple when placing / stacking rocks.
Our diverter valve came with a switch as part of the kit, but I didn't like how I was going to have to surface mount it, so I installed this one. It is in a very easy location to use without moving your hand from the loader valve controls. Arrow is the one I installed...
/ Alternative 3rd function? #12
I've got a NH 3040 with the same joystick. I bought the diverter valve and am about to put it together. Do you remember if the hoses with the couplings coming out of the old valves along with the hoses coming out of the metal tubing along the top arm of the loader are jic or npt fittings?
/ Alternative 3rd function? #13
this is how i did mine , on the 3rd function it was around $640.00 for everything ..
Thanks for all the info and pics... I still haven't decided, but I now think that decision will be harder to make! You guys have covered all the bases, plus some more that I didn't even think of.
I'm going to start pricing out different ways ..... right now I have very shallow pockets. I may just save a bit more and do it the right way instead of cheaper
Thanks again!
/ Alternative 3rd function? #15
I got my diverter valve and switch from Summit.
/ Alternative 3rd function? #16
Thanks again!
Trying to skimp or do something cheap hardly ever pays off.
/ Alternative 3rd function? #17
Whatever it costs it is well worth it IMO
It's like anything, once you get it you will find uses for it. Not to mention the buttons on the joystick are pretty damn convenient.
The kit is a bargain you will soon learn if you have to source hoses, fittings and other parts individually.
Pay now or pay later.
Still in process trying to source all of the parts.... some places have this, others have that....
I am still leaning towards a 'kit', but I'll keep searching.....
/ Alternative 3rd function? #19
Kits are nice but I have about $250 in extra parts that I might never use, sitting in a bag on a shelf in the basement (just in case)!!! :ROFLMAO:
(really wish this was a joke but it's not...)
/ Alternative 3rd function? #20
i do have a extra set of hoses to hook up to the 3rd function , when i bought mine i didnt fully understand hydraulics so i bought 2 complete sets of hoses and the fittings .. a $90.00 lesson learned,,
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
GATOR UTV (A63276)
GATOR UTV (A63276)
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
