Electric Top Link
/ Electric Top Link #1
Hayloft
Western Wash
3520HST
Anybody install an actuator for adjusting tractor top Link ?
/ Electric Top Link #3
Here is a link to another thread discussing this....
/ Electric Top Link
Yeah, well I don't know much about selecting the right actuator for this job but there are some pretty hefty heavy duty actuators out there, from hundred lbs force up to more than 1,000 lbs force. When using a manual top link cylinder it doesn't take that much force for sure. Seems the rod ends would likely need to be modified to fit the cat 1. Still looking.
/ Electric Top Link #5
Simply adjusting the length is not the load that I'd worry about.
It's the 6' - 7' wide implement and the shock loads, picture a box scraper backing up doing a little grading/pushing backwards and you "catch" a rock or stump bringing the tractor to an immediate stop, or driving the tractor back to the house after bush hogging in a higher gear and you cross that little bump or groundhog hole and that you forgot about and the heavy mower gets thrown up and down pretty violently....
They don't use 3/4" or bigger acme threaded rod if it weren't a necessary. 👍 minimum.
/ Electric Top Link #6
A linear actuator with sufficient load rating is gonna cost you maybe 3 times what a cylinder will, and then you'll have to modify the ends because none of them come with the ends that will fit a top link.
Been running large farm tractors with many, many rear mounted implements for the last 35 years and I've never felt the need for a TNT.
/ Electric Top Link
All good points. And I guess if electric top links was a good idea there would already be a ton of products on the market! Thanks for the discussion !
/ Electric Top Link #8
I never had a hyd top link until I bought my last tractor. One of the best things I ever bought. I just put an Ag South el cheapo on it.
/ Electric Top Link #9
There was an electric over hydraulic top link posted here on TBN a while back. Need to find it again as I don't remember the details. It might be the answer for someone who doesn't have and doesn't want to add rear remotes.
/ Electric Top Link #10
Hayloft now you've reminded me that there is a hydraulically adjustable top link that's self contained. You can't adjust it from the seat but.... I'll look for a link or name.
/ Electric Top Link #11
Not sure if this accomplishes what you're looking for but it's cheaper than adding a circuit to your tractor unless you're able to put it together yourself.
Edit; nope in reading the q&a apparently it's just a strange looking cylinder that requires a hydraulic circuit. Not sure why I thought it was self contained but obviously I didn't read enough about it.
/ Electric Top Link #12
May it was the Hydraulink that you were looking for?
Looks like it's been discontinued anyway.
/ Electric Top Link #13
I believe it was a hydraulic cylinder with a 12 VDC powerpac mounted on it.
/ Electric Top Link #14
That's the one. It's been a while since I first saw it and I was thinking about a different application for one.
Thanks, that helps me with my self confidence, at least of my memory. 😆
Too bad it's discontinued.
/ Electric Top Link #15
/ Electric Top Link #17
Even a 1000lb actuator is way too small for even most compact tractors.
For a mid-30ish HP compact....Id consider a 2" hydraulic cylinder as the bear minimum. And at 2500psi and a 1" rod....thats good for ~7,800lbs extending and ~5900lbs retracting.
Gotta handle the dynamic shock loading as already mentioned when you have a heavy implement in transport.
And anything that is ground engaging is putting ALOT of force on the toplink. A blade, plow, subsoiler, etc. Its trying to rotate around your 3PH arms. So the force below the arms where said implement is doing its work is translated into trying to compress the toplink
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
FIXED FIFTH WHEEL ATTACHMENT (A63569)
FIXED FIFTH WHEEL...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
CAT Flat Bottom High-Capacity Material Bucket (A64047)
CAT Flat Bottom...
2019 CATERPILLAR 299D2 XHP SKID STEER (A64279)
2019 CATERPILLAR...
