Electric Top Link
/ Electric Top Link #11
Not sure if this accomplishes what you're looking for but it's cheaper than adding a circuit to your tractor unless you're able to put it together yourself.
Edit; nope in reading the q&a apparently it's just a strange looking cylinder that requires a hydraulic circuit. Not sure why I thought it was self contained but obviously I didn't read enough about it.
/ Electric Top Link #12
May it was the Hydraulink that you were looking for?
Looks like it's been discontinued anyway.
/ Electric Top Link #13
I believe it was a hydraulic cylinder with a 12 VDC powerpac mounted on it.
/ Electric Top Link #14
That's the one. It's been a while since I first saw it and I was thinking about a different application for one.
Thanks, that helps me with my self confidence, at least of my memory. šŸ˜†
Too bad it's discontinued.
/ Electric Top Link #15
/ Electric Top Link #17
Even a 1000lb actuator is way too small for even most compact tractors.
For a mid-30ish HP compact....Id consider a 2" hydraulic cylinder as the bear minimum. And at 2500psi and a 1" rod....thats good for ~7,800lbs extending and ~5900lbs retracting.
Gotta handle the dynamic shock loading as already mentioned when you have a heavy implement in transport.
And anything that is ground engaging is putting ALOT of force on the toplink. A blade, plow, subsoiler, etc. Its trying to rotate around your 3PH arms. So the force below the arms where said implement is doing its work is translated into trying to compress the toplink
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
Deere 410L (A53317)
Deere 410L (A53317)
2011 Ford F-750 Terex Hi-Ranger 5TC-55 55ft. Insulated Bucket Truck (A60352)
2011 Ford F-750...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
XCMG CV83PD (A53317)
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A59908)
2006 CHEVROLET...
