If there are aliens, what will they look like?
   / If there are aliens, what will they look like? #591
This seems to fit in with the discussion. Coincidence? Or is an alien mind manipulating our thoughts? I'll let you decide.
   / If there are aliens, what will they look like? #593
It's all explained by relative density. Things float if lighter than air. Things fall if heavier than the medium (air, water).
Why fall? Why not in some other arbitrary direction?What is the driver that chooses that particular vector?
By the exhibit you posted, it seems that your claim is that anti-buoyancy makes the bolt want to move downward.
   / If there are aliens, what will they look like? #594
Now wouldn't it be something...
IF.. the aliens had mastered gravity, bent it to their will, and use it to get around .??
"In and out the Planets"
   / If there are aliens, what will they look like? #595
That would explain the apparent lack of any effect of inertia on some UFOs, wouldn't it?
   / If there are aliens, what will they look like? #596
   / If there are aliens, what will they look like? #597
We know by observation that lighter things float and heavier things fall or sink.
   / If there are aliens, what will they look like? #598
That observation has it's flaws.
A sheet of steel, placed on the surface of water. (steel is "less light" than water, by most observations.
the steel falls or sinks.
Same piece of steel. but with all it's edges folded up and welded tight. Place that (correctly) on the water surface, and it "floats". Same steel, same water, different observation.
A fault in the logic...
Freightliner Tender Truck - Adams Tender (A56438)
Freightliner...
1996 Ford Ranger Pickup Truck (A59230)
1996 Ford Ranger...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
