If there are aliens, what will they look like?
   / If there are aliens, what will they look like? #582
This thread is spurring some real serious questions:
- What is my loader lift capacity on flat earth vs round earth?
- Can aliens get New Holland parts on Alpha Centori?
- Should I use anything other than Super UTD2 in my intergalactic spacecraft?
   / If there are aliens, what will they look like? #583
Bwa, HAHaha!!!
You’re asking some pretty difficult questions now!
   / If there are aliens, what will they look like? #584
What would aliens look like?
   / If there are aliens, what will they look like? #585
So if we take the average CUT that can lift 2k to full height to Mars and bring along oxy /nitrogen tanks to keep the engine running.
The FEL could lift close to what would weigh 5500lb on earth.
Cool
   / If there are aliens, what will they look like? #586
That's looks like me the day after drinking rum all night, then having a guzzling contest with Everclear 190.
If you guzzled Everclear, you're lucky you didn't burst into flames or pickle yourself into a mummy for posterity. I used to buy it, and dilute it 50/50 with distilled water to make my own vodka. Why? Because I thought it would reduce my allergies. All I know was it was potent stuff.
   / If there are aliens, what will they look like? #589
Proof! It's on the internet!
N.B. (I didn't watch the entire episode ;-)
eta
What is really scary is that I don't go looking for this sort of crap. I'm thinking since I do enjoy THIS THREAD, the evil "Al-Gore-rhythms" are putting this onto my corn-puter.
It's a possibility!
   / If there are aliens, what will they look like? #590
That was a really weird interview. A little bit of truth, a little bit of fantasy land?
Whacky if you ask me... but a lot is worth a consider. It's just likely not Lizard people......
   / If there are aliens, what will they look like? #591
This seems to fit in with the discussion. Coincidence? Or is an alien mind manipulating our thoughts? I'll let you decide.
   / If there are aliens, what will they look like? #593
It's all explained by relative density. Things float if lighter than air. Things fall if heavier than the medium (air, water).
Why fall? Why not in some other arbitrary direction?What is the driver that chooses that particular vector?
By the exhibit you posted, it seems that your claim is that anti-buoyancy makes the bolt want to move downward.
   / If there are aliens, what will they look like? #594
Now wouldn't it be something...
IF.. the aliens had mastered gravity, bent it to their will, and use it to get around .??
"In and out the Planets"
   / If there are aliens, what will they look like? #595
That would explain the apparent lack of any effect of inertia on some UFOs, wouldn't it?
   / If there are aliens, what will they look like? #597
We know by observation that lighter things float and heavier things fall or sink.
   / If there are aliens, what will they look like? #598
That observation has it's flaws.
A sheet of steel, placed on the surface of water. (steel is "less light" than water, by most observations.
the steel falls or sinks.
Same piece of steel. but with all it's edges folded up and welded tight. Place that (correctly) on the water surface, and it "floats". Same steel, same water, different observation.
A fault in the logic...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
1996 International Water Truck with a Caterpillar Engine (A56438)
1996 International...
