If there are aliens, what will they look like?
   / If there are aliens, what will they look like? #591
This seems to fit in with the discussion. Coincidence? Or is an alien mind manipulating our thoughts? I'll let you decide.
   / If there are aliens, what will they look like? #593
It's all explained by relative density. Things float if lighter than air. Things fall if heavier than the medium (air, water).
Why fall? Why not in some other arbitrary direction?What is the driver that chooses that particular vector?
By the exhibit you posted, it seems that your claim is that anti-buoyancy makes the bolt want to move downward.
   / If there are aliens, what will they look like? #594
Now wouldn't it be something...
IF.. the aliens had mastered gravity, bent it to their will, and use it to get around .??
"In and out the Planets"
   / If there are aliens, what will they look like? #595
That would explain the apparent lack of any effect of inertia on some UFOs, wouldn't it?
   / If there are aliens, what will they look like? #596
   / If there are aliens, what will they look like? #597
We know by observation that lighter things float and heavier things fall or sink.
   / If there are aliens, what will they look like? #598
That observation has it's flaws.
A sheet of steel, placed on the surface of water. (steel is "less light" than water, by most observations.
the steel falls or sinks.
Same piece of steel. but with all it's edges folded up and welded tight. Place that (correctly) on the water surface, and it "floats". Same steel, same water, different observation.
A fault in the logic...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
