tradosaurus
Super Member
- Joined
- May 8, 2017
- Messages
- 5,975
- Location
- Texarkana, TX
- Tractor
- Kubota MX5400 HST, heavy duty bucket, 3rd function, R1 tires (rears filled), 2 remotes
Uh oh you are using big words. I'm getting scared.You certainly didn't understand much while you were in those classes nor much of the average subjects that pop up in life.
So for starters you are basically saying you don't understand inertia or relative velocity.
I'm almost too scared to ask if you in fact are a flat earther. That would actually explain a great deal.
You do understand that if the earth were rotating 1,000 mph at the equator the rotational speed at the poles would be zero?
This would mean that as you travel from equator to north or south pole the rotational velocity would be less and less AND your weight would be affected to some degree.
Do you also understand that you cannot bend water without a container? Water always seeks its level when left to atmosphere, which is why its called sea-level.
So keep speaking down to me while I point out more absurdities of the globe earth universe.
