How much does it cost to build a pole barn and what kind is best..
/ How much does it cost to build a pole barn and what kind is best.. #1
Reddogs
Gold Member
John Deere 790 / Kubota L3301
If you want to build a 20 by 40 pole barn, what kind should you build, and what should it cost? Is metal or wood better, and where can you get the materials or is a prefab cost the same considering time and effort...
/ How much does it cost to build a pole barn and what kind is best.. #2
Open or enclosed? Free span or not? Concrete floor, rock, dirt?
I built a 24X36 that was basically just posts in the ground and a metal roof for $3,000 at the end of last year.
Good point, I need it for my tractors, so open, and I can pour concrete as its over an acre of open area, so trucks can get in. But what is 'free span'...??
/ How much does it cost to build a pole barn and what kind is best.. #4
Posts in the middle or not. I opted for posts. That saved the expense of trusses and less square footage for roofing materials. My posts are set in a 12'x12' grid, with a 1/12 pitch front to back. I have added some bracing and graveled under it since this was taken. There was some controversy on my framing job on here, so some will probably advise better ways to frame the roof than what you see here. This works well enough for me.
/ How much does it cost to build a pole barn and what kind is best.. #5
That’s like asking “what flavor of ice cream is best”?
/ How much does it cost to build a pole barn and what kind is best.. #6
A lot will depend on how much time, labor and equipment you have available to raise the structure. Buying the materials and building your own would be cheapest. You then have the ability to select the materials you prefer, and those suitable for your location, assuming you can get them.
Prefab is the next cheapest approach but still requires the necessary labor and equipment.
Where I live, it's hard to beat outfits like Pioneer Pole Buildings for price and labor savings. Their website may give you ideas and prices which will of course vary with location:
/ How much does it cost to build a pole barn and what kind is best.. #8
My build two years ago;24x32x12' with 6/12 trusses,five windows ,man-door,12/10' over head door,metal roof and sides ,poles on 8' centers;Amish labor $2500 ,totaled $13k,no concrete.
Note;engineered trusses and regular lumber(not Amish).
We did the site work and drilled the holes,un-loaded the trucks.Build time was 2-1/2 days.
But how do you support it in the middle with no poles??
Checking their site, lets see if gives me ideas...
/ How much does it cost to build a pole barn and what kind is best.. #12
I would suggest going into the "rural living" or "do it yourself" threads and look at the projects going on there. Obviously the pitch of your roof will depend on where you live and the snow load if any.
I have built 4 pole buildings over the years. The plans are in my head. Do you have the skill to build it yourself or are you hiring it out? Doing it yourself will save you a lot of money.
As to your question; A pole barn is the least expensive way to go. I think long term metal roof/siding is best although wood gives the look of a "real" barn. And building it yourself gives a certain sense of accomplishment you cannot get from hiring it out. Cost depends on where you live and material availability. I used mostly rough cut lumber right from the sawmill. Posts also right from the sawmill.
Here are the last two I built.
Good luck and make sure to post pictures of your build.
/ How much does it cost to build a pole barn and what kind is best.. #14
That's big money down here and a crane to place them. How would you do it....?
For the size of truss you're talking about you could rent a lift of any type that would get to the height you need.
/ How much does it cost to build a pole barn and what kind is best.. #15
I didn't use them. I built what I knew I could handle easily by myself. Probably could have figured it out but for what I wanted there was not really a need.
For a 20' span you probably would not need a crane.
/ How much does it cost to build a pole barn and what kind is best.. #16
We easily lifted 28’ span 4:12 trusses by hand with 3 people. 28x32, 12’ ceiling pole building, metal sided inside and out….12x11’ door…. No hired labour, in cdn $ you’d likely have a bile taste what it's costed so far…..
/ How much does it cost to build a pole barn and what kind is best.. #17
Here is current materials only from Menards for a 24x40 with 3 enclosed sides
/ How much does it cost to build a pole barn and what kind is best.. #18
I don't know where the op is but the roof on your building looks like it might not be the best for areas that might get a snowstorm with a couple feet of snow
/ How much does it cost to build a pole barn and what kind is best.. #19
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
Rooster Weathervane (A55853)
Rooster...
