Good morning!!!!
   / Good morning!!!! #146,881
I used treated boards very successful
   / Good morning!!!! #146,882
Driving to Giddings today saw lots of $3.99 gasoline. Hard to believe it could go up to $9 a gallon but every few days it goes up 40¢.
Kyle those 2 extra screws in the duct tape in the battery compartment of the mower were left over after I took the battery compartment out looking for a short under it. There was a lot of grass inside under it that I blew out but no visible shorts. The next think is to take off the black cover that the battery case fits in but I could not access the back two screws unless I took out the motor. Thats where I stopped and just got a new mower. Good luck.
   / Good morning!!!! #146,883
In some parts of Cali (Beverly Hills?) gasoline is $9 a gallon, so they say.
BTW, has anyone bought (or priced) any True Fuel lately? Just wonder if it's going up proportionally.
   / Good morning!!!! #146,884
$9 Texas gasoline = $25 Kalifornia gasoline.
   / Good morning!!!! #146,885
These are the LED lights we are starting to have issues with.
Huge heat sink on top. The LED segments attach to the bottom. Manufacturer does not sell a replacement LED element, nor is this model even made anymore.
   / Good morning!!!! #146,886
As we all know, glyphosate is up around 250% since last year.
I found a 2.5 gallon jug of concentrate on Amazon for $66.xx with free shipping and it’s 43%. I’m sure it’s straight from China, delivery between March 11-17. They only had 8 left they said.
   / Good morning!!!! #146,887
One of the issues with servicing LED’s has been the rapid progress in design and manufacturing. The development of consumer LED has been somewhat stunning. Seemingly every year, there has been new and improved LED lights and fixtures. Sadly, the old “latest and greatest” was quickly obsoleted as design/manufacturing moved on.
Definitely sucks when your “obsolete” light dies and it has to be completely replaced
   / Good morning!!!! #146,888
We have some fixtures like that, too, BEF. This one has one LED mounted on a board in each unit, with a plastic lens over it, and a plastic bezel mounted around that to hold it in place. She told me it had started pulsing. I let it run for a couple of hours yesterday after removing all the plastic it's encased in, and it never had any problems. I'm thinking it's heat-related. It's the light over her piano, so she got annoyed when it started pulsing over her sheet music ... which I can completely understand.
I looked on the Lowe's website to find replacements, and found a plethora of bad reviews commenting on the same thing; units go out and replacements aren't readily available. The distributor did reply on a couple of them offering to get them parts, so I'm going to contact them to see what they can do. We like the light, but may have to eventually replace it with something more serviceable. For now, I'll see if I can get parts to keep it working.
Naturally, it's 5-year warranty has just expired. :rolleyes:
Tell her to play like Keith Emmerson from ELP with a strobe light effect. :)
The lawn mower is dropped off, (thanks Don (I hope)). Thanks for the heads up....maybe I've bitten off more than I can chew. Don, I'm assuming you already checked the 3 relays and the possible red small wire that goes up the handlebars for a short? Electronics is not my forte....but I do have a new test light.
Hydraulic cylinder sitrep...So I got the first "bent rod" cylinder repaired. Took apart it's twin (the one that I posted the bent rod pic of), and went down and ordered the bare minimum orings and seals to repair it. Took the bent rod over to my buddy's press, put his nice Mitutoyo jeweled indicator underneath the rod, so I could tell how far I was bending it.... Using mental data from the successful repair of the 1st unit, I put 5 tons on it, and it just sprang back to it's bent condition. I put a bit more on it and the same. So I put a wee bit more force on it and BAAMM! It cracked and put a hit on the indicator, breaking it's tip off and now it's "notchy" in it's movement. So I'm looking for him a new indicator of like quality and build, since the model he has/had is no longer offered. Ugh. And now I'm needing to buy about 24"+ of 32mm diameter hydraulic rod stock. It turns out that most is offered in cold rolled 1045 stock and often induction hardened. It has 75k yield in this condition, but I've found some chrome moly 4140 chrome plated stock with 100k yield, for about $150. less tax and shipping which is about 20lbs worth. I will have to thread one end and weld the other end to the crosstube rectangle yoke. Deere wants $500 for a new rod, and a bit over $1000 for a whole new hydraulic cylinder. Ugh again.
   / Good morning!!!! #146,890
Sorry for the bad luck Kyle.
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
2014 Jeep Grand Cherokee SUV (A56859)
2014 Jeep Grand...
1995 Advance Mixer CM3A6811 11 Yard Tri-Axle Concrete Mixer Truck (A56858)
1995 Advance Mixer...
4800 PSI Hydraulic Hoses/CAT Hose (A57454)
4800 PSI Hydraulic...
(APPROX. 20) 4' X...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
