Should I "Upgrade"?
/ Should I "Upgrade"? #41
Did I read that the front end was light? Add fluid in the front tires and front end weights. I do a few things where I need all tires on the ground pulling. If I lose front tractor, the back spins.
/ Should I "Upgrade"? #42
I would never fill the front tires if you plan on doing any loader work.
/ Should I "Upgrade"? #43
I went from a Ford 1700 4WD @ ~ 4000# to a Kubota M6040 4WD that weighs 10,100#. The difference in weight and pulling abilities were monumental. More than double the hp didn't hurt either.
I pull BIG pine logs - I needed a bigger tractor.
/ Should I "Upgrade"? #44
Why not? Weight in or on tires does not ride on the front wheel bearings. The front wheel bearings support the weight of the tractor or what is in the FEL.
/ Should I "Upgrade"? #45
Front tires are notorious for rolling off the bead during heavy loader work. Liquid fill cannot help this situation.
/ Should I "Upgrade"? #46
Never had a tire roll off the bead doing loader work. Hay or logs. But I don't overload it.
I have had the front tires lose traction pulling subsoiler, heavy back blade.
/ Should I "Upgrade"? #50
Never had one roll off the bead either.
I've personally never had one roll off of a bead, but was working with somebody who rolled one off once. They were digging in muddy soil and rolled a bead off one of the front tires of their MFWD tractor turning with a bucket full of heavy mud. The fronts were not filled.
/ Should I "Upgrade"? #51
I'm not saying it couldn't happen. I've just never seen it.
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2015 Peterbilt 567...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
2012 PETERBILT 367 (A60736)
2012 PETERBILT 367...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
INSPECTION (A61165)
INSPECTION (A61165)
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
