DIY TRACTOR SNOW PLOW
/ DIY TRACTOR SNOW PLOW #1
ProRemodler
John Deere 5055d
After a couple years of debating, I built my perfect snow plow. Pictures included. I bolted a 4x4 to the bucket (already had holes) 7 ft wide. Then bolted a 2x12 and 2x6 together to the 4x4. 1/2” carriage bolts. Added a 2x4 to the top to help curl the snow. Then added 1/2 thick x 3” rubber strip from a horse stall mat. The rubber hangs below the wood about 1x2”. First snow was about 7”. I have a lot of concrete at my little farm. As you can see it worked very well took about 30 minutes.
/ DIY TRACTOR SNOW PLOW #3
If it works, that's all you need. Just pushing snow around. Anything is better than shoveling.......
boards may warp after awhile due to the snow melting/freezing, but easily replaceable
You are right 009. Easy to replace if needed. Pretty simple design.
/ DIY TRACTOR SNOW PLOW #5
Very useful!
I've seen snow pushers made from heavy equipment tires. I'm thinking of going that way myself. ;-)
/ DIY TRACTOR SNOW PLOW #6
LOL, reminds me of a plywood and bed angle plow I hung on my old VW 'Bug" way back when.
My sophisticated lift was a rope and hockey stick lever and open driver's window, but WYH it worked!
/ DIY TRACTOR SNOW PLOW #7
After a couple years of debating, I built my perfect snow plow. Pictures included. I bolted a 4x4 to the bucket (already had holes) 7 ft wide. Then bolted a 2x12 and 2x6 together to the 4x4. 1/2” carriage bolts. Added a 2x4 to the top to help curl the snow. Then added 1/2 thick x 3” rubber strip from a horse stall mat. The rubber hangs below the wood about 1x2”. First snow was about 7”. I have a lot of concrete at my little farm. As you can see it worked very well took about 30 minutes. View attachment 736110View attachment 736111View attachment 736112View attachment 736113
Nice job! I like the strip of stall mat, something to "give" if you snub up on something like a protruding rock.
Exactly. As he said below...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
Caterpillar 416-442D Backhoe Service and Parts Manuals (A63117)
Caterpillar...
CRATE OF UNUSED KUBOTA PARTS & BRACKETS (A64280)
CRATE OF UNUSED...
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A59912)
2019 INTERNATIONAL...
2004 PETERBILT 379 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2004 PETERBILT 379...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
