DIY TRACTOR SNOW PLOW
/ DIY TRACTOR SNOW PLOW #1
ProRemodler
John Deere 5055d
After a couple years of debating, I built my perfect snow plow. Pictures included. I bolted a 4x4 to the bucket (already had holes) 7 ft wide. Then bolted a 2x12 and 2x6 together to the 4x4. 1/2” carriage bolts. Added a 2x4 to the top to help curl the snow. Then added 1/2 thick x 3” rubber strip from a horse stall mat. The rubber hangs below the wood about 1x2”. First snow was about 7”. I have a lot of concrete at my little farm. As you can see it worked very well took about 30 minutes.
/ DIY TRACTOR SNOW PLOW #3
If it works, that's all you need. Just pushing snow around. Anything is better than shoveling.......
boards may warp after awhile due to the snow melting/freezing, but easily replaceable
You are right 009. Easy to replace if needed. Pretty simple design.
/ DIY TRACTOR SNOW PLOW #5
Very useful!
I've seen snow pushers made from heavy equipment tires. I'm thinking of going that way myself. ;-)
/ DIY TRACTOR SNOW PLOW #6
LOL, reminds me of a plywood and bed angle plow I hung on my old VW 'Bug" way back when.
My sophisticated lift was a rope and hockey stick lever and open driver's window, but WYH it worked!
/ DIY TRACTOR SNOW PLOW #7
After a couple years of debating, I built my perfect snow plow. Pictures included. I bolted a 4x4 to the bucket (already had holes) 7 ft wide. Then bolted a 2x12 and 2x6 together to the 4x4. 1/2” carriage bolts. Added a 2x4 to the top to help curl the snow. Then added 1/2 thick x 3” rubber strip from a horse stall mat. The rubber hangs below the wood about 1x2”. First snow was about 7”. I have a lot of concrete at my little farm. As you can see it worked very well took about 30 minutes. View attachment 736110View attachment 736111View attachment 736112View attachment 736113
Nice job! I like the strip of stall mat, something to "give" if you snub up on something like a protruding rock.
Exactly. As he said below...
2005 International 4300 55' Bucket Truck (A62613)
2005 International...
4 Bottom Plow (A65640)
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
John Deere 5M Series Tractor Loader Frames (A65640)
John Deere 5M...
AR500 Deer Target (A65640)
AR500 Deer Target...
(8) John Deere Suitcase Weights (A65640)
(8) John Deere...
