DIY TRACTOR SNOW PLOW
   / DIY TRACTOR SNOW PLOW #1
ProRemodler
John Deere 5055d
After a couple years of debating, I built my perfect snow plow. Pictures included. I bolted a 4x4 to the bucket (already had holes) 7 ft wide. Then bolted a 2x12 and 2x6 together to the 4x4. 1/2” carriage bolts. Added a 2x4 to the top to help curl the snow. Then added 1/2 thick x 3” rubber strip from a horse stall mat. The rubber hangs below the wood about 1x2”. First snow was about 7”. I have a lot of concrete at my little farm. As you can see it worked very well took about 30 minutes.
   / DIY TRACTOR SNOW PLOW #2
There is beauty in simplicity 👍
Looks like does a good job for you!
   / DIY TRACTOR SNOW PLOW #3
If it works, that's all you need. Just pushing snow around. Anything is better than shoveling.......
boards may warp after awhile due to the snow melting/freezing, but easily replaceable
You are right 009. Easy to replace if needed. Pretty simple design.
   / DIY TRACTOR SNOW PLOW #5
Very useful!
I've seen snow pushers made from heavy equipment tires. I'm thinking of going that way myself. ;-)
   / DIY TRACTOR SNOW PLOW #6
LOL, reminds me of a plywood and bed angle plow I hung on my old VW 'Bug" way back when.
My sophisticated lift was a rope and hockey stick lever and open driver's window, but WYH it worked!
   / DIY TRACTOR SNOW PLOW #7
After a couple years of debating, I built my perfect snow plow. Pictures included. I bolted a 4x4 to the bucket (already had holes) 7 ft wide. Then bolted a 2x12 and 2x6 together to the 4x4. 1/2” carriage bolts. Added a 2x4 to the top to help curl the snow. Then added 1/2 thick x 3” rubber strip from a horse stall mat. The rubber hangs below the wood about 1x2”. First snow was about 7”. I have a lot of concrete at my little farm. As you can see it worked very well took about 30 minutes. View attachment 736110View attachment 736111View attachment 736112View attachment 736113
Nice job! I like the strip of stall mat, something to "give" if you snub up on something like a protruding rock.
Exactly. As he said below...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2022 FORD E350 BOX TRUCK (A57880)
2022 FORD E350 BOX...
2007 Sterling Derrick Digger Truck (A55973)
2007 Sterling...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
