New Member - SA424, LX2610SU, or L2501
/ New Member - SA424, LX2610SU, or L2501 #41
You really need to get on these different tractors
and test drive them so you can tell if they suit you
for where the controls are. Just so you know if the
controls are handy for you .We can tell you what
we have and like but every one is different in what
they like and dislike. You can have a tractor with
no problems and your neighbor just might have the
same tractor with problems maintenance plays a
big factor in how your tractor will last.
willy
Well, the L2501 is out of the picture. Jeff was 100% correct that it is way too big for my property and will be difficult to maneuver. I was also considering the CK2610 Kioti after considering some recommendations and that is also entirely too big.
I got a quote today for a Kioti CX2510HST with telescoping arm, linked pedal, rear remote, and hydraulic top link for $20k OTD. I also want to take a look at the LX2610SU and price it out with similar options (I am afraid it will cost $5k more but I haven't gotten quotes yet).
On paper the CX2510 has larger displacement and weighs about 500lbs more than the LX2610SU. The LX2610SU has 3 range HST vs the 2 on the Kioti and has a larger 3pt lift capacity and 1 extra PTO hp than the Kioti. The loaders (LA535 and KL2510) at similarly spec'd. I am leaning towards the Kioti but I also want to consider the competition to make sure I don't end up wondering later.
Will the 2 vs. 3 range have that much of a difference for my uses (I believe all loader work will be in high range anyway)?
Is there a downfall to Kioti making max HP @ 2600rpm vs. 2200rpm on the Kubota?
Any thoughts on the two considering I need it primarily for loader work? I've found no comparisons on the LX2610SU and the CX2510 anywhere on the web - only the B2650 and the CK2510 which are older and slightly different with smaller B and larger CK suggestions mixed in.
/ New Member - SA424, LX2610SU, or L2501 #43
More than likely, you WON'T be using high range for loader work. Depending on the material you're working with, stone / gravel for instance, will be much more compacted and heavier that landscaping mulch. You would need to be in low range in order to push into the pile. Something ligher and high range would be ok.
Doing loader work such as back dragging or pushing / leveling material, may work in high range. It is really a 'trial and error' kind of thing. The tractor will let you know if you're overworking a range.
I'm surprised that you said the Kioti "out-spec'd" the LS225-S.... loader lift is within 25lbs, but the LS has a bucket 4" wider. The breakout force on the LS loader is 2290 lbs, the Kioti breakout is 1843 lbs. The LS will 'dig' 4.5" deep vs the Kioti at 3.9" (I know, only a 1/2"). The 3 point on the LS also lifts 1896lbs, vs the Kioti at 1203 lbs.
The LS has a 3 range vs the Kioti 2 range trans. The LS is a little lighter by about 200 lbs. PTO hp is the same at 19.3
Not sure if there is a dramatic price difference between the two, and YOU have to be the one to sit on them and be comfortable. The 3 range trans would make the deciding factor for me, but just my opinion. They are both great tractors.
You are correct and I was wrong! I don't know which LS I looked at but I was comparing L2501 vs CK2610 vs LS MT225s which is not a good comparison lol. My apologies. The LS lineup was a bit confusing to me. Now that I have seen a few of their models, the MT225HE is a solid contender against the aforementioned units.
Sadly, the 3 above will be too large for my property but I will look at the MT225s now that I know it's sized right for my property and uses a Yanmar diesel engine 😁 We only have one LS dealer nearby so I'll have to swing by and look when I do my Kubota run.
Thank you for the tip on the HST range vs. use case for loader work.
/ New Member - SA424, LX2610SU, or L2501 #45
You are welcome! My neighbor had a 225-S and I was impressed with that tractor. Very maneuverable, lots of nice features. Powerful for it's size. He dug just under 200 post holes without a problem in our hard clay soil.
I had the MT125 TLB and it was a workhorse. 220 hard hours without an issue. If the 225-S was available when I upgraded, I would have gotten it instead of my XG3025 (same as the 225HE). Don't get me wrong, I absolutely love the bigger 225HE, but the S version is a lot more maneuverable in some instances.
I wish I could afford both!:ROFLMAO:
/ New Member - SA424, LX2610SU, or L2501 #46
I would definitely lean toward the L2501 simply because it is heavier and therefore will be more stable. It's less likely to feel "too small" for the job. On the plus side, it appears the loader on the 2501 has more lift. Tractordata.com lists the LX2610 lifting 769 pound to full height at 500mm from the pin and the L2501 lifting 1182 pounds at 500mm plus it has 10 inches more lift.
I agree. Go with the L2501. You with enjoy the extra weight and frame size for cutting and moving dirt.
/ New Member - SA424, LX2610SU, or L2501 #47
I would ask what the rear axle material is made of on both tractors. I believe that the Kubota is cast aluminum and the kioti is cast iron.
I once worked for a sidewalk plowing company in Toronto and we had 2 Kubota 30/30 sidewalk plows break their rear axles in the same week when the rear tires came into contact with a fire hydrant when passing. 2 identical accidents on 2 separate nights with 2 separate operators.
Accident had a lot to do with the machines coming with the "wide" rear wheel setup instead of the "narrow " kit it had been ordered with. And yes our 2 operators hit the hydrants so the axles didn't break on their own.
But this was the main reason that I purchased a new 2022 Kioti CX2510 CUT to replace my 2014 CS2410 SCUT.
I believe aluminum has its place in machinery, but we quite often end up adding weight to a tractor to enhance the operation, especially when doing loader work.
So I don't know if Kubota axles are still made of aluminum. I never inquired when I bought either tractor.
When the rear axle on both 30/30's broke we had a hard time getting them fixed under warranty since our Operators had done the hitting, but the nature of sidewalk plowing requires that the plow travel down the sidewalk and the wider rear wheels wouldn't have come into contact with the hydrant IF the tractor had come with the narrow tire option as ordered.
They ended up covering both tractors with us responsible for transporting the machines back and forth and we had to find back up machines while ours were being repaired.
For full disclosure I've avoided Kubota since this incident. Which left me only really considering Kioti or John Deere. Price on the Kioti is about 20000 cheaper were I live and I don't need to deal with JD's proprietary bucket attachment system.
The kioti uses the much more common "Bobcat" quick attach system.
I believe that Kubota produces a good product and under normal use an aluminum rear axle should be fine. But I had ZERO problems with my 2014 CS2410 over 7 years of ownership and I loved it so much that I never considered anything other then a Kioti to replace it. And I only replaced it for a larger tractor, otherwise I believe I could have gotten 20 or 30 plus years of service based on my 100 or so hours of use per year and kept it.
I hope this helps.
I hope this helps.
I will do that, I believe the Kubota B/LX is cast aluminum vs. cast iron but I could be wrong. It was actually your recommendation and a lot of the favorable reviews on the forum that had me convinced to check out the Kioti. I was impressed.
/ New Member - SA424, LX2610SU, or L2501 #49
I hope this helps.
My MX axle is made of cast steel. I have never heard of Kubota axles being made of aluminum (JD does this on the smaller series). Maybe Kubota does this on the BX series?
Welp, put a deposit down on a crated CUT today. Got a sweet deal on a "Kaboter" LX2610 (non-SU) model and after test driving, I am a huge fan. The size is on the larger side for our current property, but not too small if we upgrade to 5-10 acres in the near future.
For reference, it is bigger than the CX2510 I was considering, but slightly smaller than the CK2610 and L2501. It worked out to being roughly $2-3k more than the CX2510 in the end and Kubota's financing is currently more favorable than Kioti's. I know the CX2510 weighs about 350lbs more, but I've compensated for that by having the rear tires filled with beet juice. What ultimately sold me was the 3 range HST for my property which has some steep hills/inclines and the dealer network is way more refined in my area (there are quite a few within a 100 mile radius). If Kioti's presence was greater in my area, I may have swung the other direction despite the transmission shortcoming.
My "Kaboter":
LX2610
R14s (17.5s)
Dual rear remotes
LA535 loader with skid steer QA
54" bucket from a B instead of the 60" LX
Once we recover from a few upcoming house projects, I plan on adding:
QA forks
Third function
Rear hydraulic top link
Box Blade
Grapple
Bucket scoop
Bucket EA teeth
Thank you all again for your advice! I will share some photos when my tractor is delivered.
/ New Member - SA424, LX2610SU, or L2501 #51
Congrats on your new tractor! Be sure to post some pics when you get it!
She showed up early this morning, what a beast! I drove her around for a bit and let my son get some seat time long enough to snap a photo or two. Thanks again for the advice, this is plenty tractor for my property.
/ New Member - SA424, LX2610SU, or L2501 #53
Almost as good as a Kioti. Lol
Ha! Honestly you can't go wrong with any modern diesel... I almost pulled the trigger on that CK2510 but changed my mind for a few reasons mainly dealer support related.
1. There's a dealer close to me, however, they are a small operation and longevity was a concern. The other one nearby was quite a bit pricier.
2. There was only one source of online parts that I could find for Kioti's besides routine maintenance items like filters and oil, this was another consideration for me as I was easily able to locate 5-10 online dealers for Kubota OEM parts.
3. Not much of a pricing difference for me to forego the third gear and independent PTO on the LX2610 vs the 2 gear and live PTO on the ck2510.
Again, not knocking the Kioti - I was a huge fan of what I saw and if I had more property I would have gone with the CK2610 for sure.
/ New Member - SA424, LX2610SU, or L2501 #55
Congratulations you will find endless things to do with your new tractor.
Thank you Richard, gonna break her in proper this weekend by moving 1 whole yard of 6A limestone lol - gotta start small 😂
/ New Member - SA424, LX2610SU, or L2501 #57
Dealer issues are a big problem here in Ontario. And parts and consumables are hard to find. I would certainly like the Kubota for that.
But I have a question for you, is your rear axle cast iron or cast aluminum?
I used to run a sidewalk crew and we purchased several Kubota 30/30 sidewalk plows. 2 of these units suffered catastrophic rear axle failures when my operators allowed the rear wheels to "slightly" come into contact with a fire hydrant. I say slightly since the contact didn't even remove any paint.
I've been leary of Kubota since then.
It's aluminum vs. cast iron. I don't have concerns there because I opted for the KTAC insurance so if there is any sort of catastrophe besides act of war, negligence on my part, or terrorism, the unit is covered. I'll be operating the unit in a residential setting as well, with limited opportunity for such failures.
/ New Member - SA424, LX2610SU, or L2501 #59
Congrats. I'm not familiar with the tractor you've bought so I don't know how much of this actually applies to your tractor.
You might want to take a few minutes and research or at least look at your filter locations to assess whether they are vulnerable to damage. Some people are putting guards on their filters that are under the tractor on the L2501 model, I don't know if your LX model is similar.
Adding expanded metal to the front guard to protect the plastic grill is also another good idea. And the taillights on the fenders are vulnerable to damage if you back into something.
I could see where some brush might want to snag the exhaust pipe.
Just a few things to hopefully save you some money.
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
UNUSED RAYTREE RMBD72ST-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
(20) WOOD PALLETS (A60432)
(20) WOOD PALLETS...
2025 Kivel 48in. Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
