Andrew Camarata
/ Andrew Camarata #321
The blast video starts mid summer with everything green and in full foliage...it is finally cleaned up in late fall with the trees bare.
The most meaningful scene was from the drone, with Andrew standing on the roof of his biggest loader after the work was done.
He had to be feeling on top of the world...
/ Andrew Camarata #326
from what I see, Andy makes more from YT than anything else.
I agree. Sure beats the pants off of popping out a few tons of hay. At his rate he will be worth 10 million in a few more years.
/ Andrew Camarata #327
his latest video is pretty tame but shows his excellent skills laying down gravel with the bucket of an excavator
I always take the time to change the resolution to what is called 5k, my pc will handle it and the clarity of his camera work
is very cool.
And I'm glad his dog found his old friend frisbee.
This last one has most of his equipment on display.
/ Andrew Camarata #328
I couldn't come close to spring spreading gravel that evenly with the bucket on my tractor. Maybe if I had that much gravel to practice with, I'd develop the skill.
/ Andrew Camarata #330
Cued to start at the fun part. Watch for the next minute where things go south. He's lucky.
/ Andrew Camarata #331
It started from the start. What part is the fun part?
/ Andrew Camarata #333
this is worth watching. First he fixes the winch on his dozer and then uses it to pull an old Subaru Outback literally in half, at the end.
actually quite entertaining.
Nice 5k video, my new monitor supports it and his stuff when focused right on is really good to look at. That drone he uses must be high end for 5k; just glad
he uses it. His stuff defaults to a lower setting but if you have a good monitor, you can go into the menu and pick the highest available. The difference between 1080 and 4k is huge, not sure what 5k does. Probably requires 5G to stream it.
it was nice to see him working on big old equipment again, and taking his time to do it right.
/ Andrew Camarata #334
So that winch was fully hydraulic? he said some stuff in a previous video that confused me or I misheard him.
/ Andrew Camarata #335
I believe he said the winch was PTO driven and the brake and whatever the other control was, is hydraulic.
/ Andrew Camarata #336
The pto drives the hydraulic pump. The pump powers the winch. The pto has a forward, neutral and reverse to change the direction on the cable and allows a neutral position.
/ Andrew Camarata #337
The hysters I believe the gearing is on the hydro side.
/ Andrew Camarata #338
The video is worth watching in its entirety if you're a gearhead.
/ Andrew Camarata #339
Yeah I was curious because I thought he said mechanical with hydraulic controls or something.
/ Andrew Camarata #340
Could be, there might be just an on or off on the pto, but I saw no controls on the hydraulic side. I
watched the whole video. Never worked on a Hyster or a Cat, my experience has been with Komatsu,Dresser,Fiat- Allis and a couple others. Have a good one!
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
JOHN DEERE 9420R ARTICULATING TRACTOR (A64280)
JOHN DEERE 9420R...
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
2009 Caterpillar 345D Hydraulic Excavator (A61572)
2009 Caterpillar...
Odyssey Pontoon (A62613)
Odyssey Pontoon...
BUSH HOG 2720 BATWING ROTARY MOWER (A64280)
BUSH HOG 2720...
