Need Advice
/ Need Advice #1
Gzach
2010 Bobcat CT225
I am looking to buy a 2010 Bobcat CT225 and need advice.
It has: 837hrs
58" bucket
Wallenstein GX 700 belly/frame mount backhoe
66"mower deck
Asking price is 28,500.00 Canadian
Is this a fair price and could I expect any problems with the unit. I am in St Stephen New Brunswick Canada. 10 min from the Calais Maine.
Any advise would be greatly appreciated.
/ Need Advice #2
Asking price is $28,500.00 Is this a fair price?
Tractor prices vary 40% from Alaska to Georgia.
Where are you located?
Is dealer service available nearby?
Do you need a Backhoe?
T-B-N ARCHIVE: Search results for query: Bobcat CT225
/ Need Advice
/ Need Advice
The land we bought is raw forest. I think the backhoe will be good to install my septic field and dig out a root cellar etc.
/ Need Advice
The price is in Canadian. The property is completely flat.
/ Need Advice #7
$28,500 CAN = $22,350 USA.
A good price assuming the tractor has been inside stored and is in good condtion.
At 837 hours you will not need new front tires for 1,000 engine hours, nor will the tractor have been used and abused commercially.
I would not want a twelve year old tractor that was stored outside where rodents may have chewed the wiring.
/ Need Advice #8
You said any advice so my 2 cents is you mentioned two projects, do you have more?
I would consider that, maintenance cost, etc.
as opposed to cost of hiring someone and cost of renting a machine, you doing the work.
If you are thinking about using it for business purposes and able to write it off is another consideration as well as cost of a new machine that's similar. New if you'll use it a lot, it will have a warranty, maybe equipped better suited to your needs.
Then new possibly zero or low interest and investing the money you have.
How long you think you'll use it (your age).
Things I'd be thinking about.
/ Need Advice
Thank you
/ Need Advice
Thank you
/ Need Advice #11
Thank you
If it runs good and no problems the price sounds like a decent deal - and those are getting hard to find.
I would get a mechanical buddy to look at it with you. A good diesel engine is one that starts well in cold weather.
If you are not familiar with HST transmissions get someone who you trust to drive it around. That HST is the one part of a used tractor that can make a good deal into a bad one. You can fix a manual gear shifting tractor or a diesel engine and certainly electrics and hydraiulics - any of those things may be a pain, but are not fatal flaws. But a bad HST transmission is not something you want. So satisfy yourself there. The good news is that if the HST fluid looks good, and the HST itself works properly then they are very reliable. Expect that all HST transmissions will whine in too high a gear, but they sound reasonalble otherwise. The FEL hydraulic system should work fairly quickly and without excessive jerkiness. The power steering should be smooth with no jerkiness at all.
At that low hours I would expect most all the systems to be tight. .
An even better sign is when the DPO has kept maintenance records and offers you the operator and shop and parts manuals. We should be so lucky.
It will be a tremendous help doing your building work.
It is a little small to do much work in the forest.
I know, because I built our place with an even smaller one.
Yes, I know how tempting it is to do the work yourself, but I urge you no matter what tractor you buy to spend a few thousand dollars getting the major landshaping work done by a professional. Clearing and access. Maybe some digging too. If there is one thing you will thank us here on TBN for suggesting that is it. You will still have plenty to do on your tractor.
good luck,
rScotty
/ Need Advice
good luck,
rScotty
Thank you
/ Need Advice #13
Thank you
You're welcome. You know that I did about what it sounds like you are doing with a small compact tractor and have some thoughts.
I loved that compact and it's loader and hoe. Even if it did look silly with the FEL full of rocks, extra weight on the back and chains on all 4 wheels so it could pull a firewood trailer through the woods...but it pulled it. Eventually I happened upon an older larger farm tractor and an old 90 hp backhoe. Both were old with lots of hours, but still working fine and well maintained. BTW, they cost less together than a newish compact tractor. These older larger machines were orphans. Too big for suburbia. Way out of place. And just as wrong for someone wanting machines to run hard enough to make a living with - they would be shot in a month doing that. But for homeowner work done without ever straining the machine and at a much slower pace they were fine for many years yet.
Yes, of course it helps that I'm a mechanical guy - in fact it's essential. I built our house, too. Sounds like you may be doing the same.
Even working slowly and gently, the old yellow backhoe nearing 7000 hours can do in one or two easy scoops what it took the little compact an hour to accomplish. And there is almost no limit to what the front bucket can pick up. The old farm tractor still starts and runs fine. It always did. There isn't much that they can't shift. We almost never spin a tire.
Yet even with these machines I hired a bulldozer and an excavator when it was time to do some serious work.
You may have noticed that this TBN forum is oriented toward compact tractors and semi-suburban lifestyle. That's great and we love 'em. But there are other machines out there too.
rScotty
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATERPILLAR...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
2018 FORD F-350 (A65643)
2018 FORD F-350...
2020 Ford Fusion Hybrid Passenger Car, VIN # 3FA6P0WU9LR128618 (A64557)
2020 Ford Fusion...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
