You may be right. In fact I'm sure you are for most. It's that lots of scoops/min. and fast operation don't count in my work. If precise means it takes longer to do it that's just fine. Fast might count for more if I used the backhoe for digging, but I rarely use it for digging anyway.
It's local landscaping. And around here, landscaping means placing rocks.
What I like with the
M59 is that it doesn't have any slop in the pivots or flex in the system. It's stable & doesn't rock back and forth like an ex does, and has controls sensitive to small movements. I can pick up a multi-hundred pound rock, place it right where I want it, confidently position one tooth against the edge, and use all that power to smoothly and slowly slide it a few inches to the side until it drops into place.
The industrial machines I've used are more set up for large faster movements - where they shine as you say. But they don't seem to do as well slowly easing the bucket a one inch under full power at full extension.
What I do like about min ex is the full rotation and the nice cab. When things settle down and it isn't a seller's market I'll be looking into them more seriously.
Probably look first to see what Cat has to offer. What do you think of their machines?
rScotty
