MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,710
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
What you did in determining the working length of your hydraulic top link to be purchased is very typical and also is very typically wrong. You do not want to base the hydraulic unit from the manual unit. It is very common for manufacturers to use the same top link on different models to cut down on manufacturing costs and they figure "it works" and is all they care about.
I have seen factory 3pts with top links that allow 1" or less and in one case ZERO forward tilt.
Look at this link, get the asked for dimension and that should be close to what you want for a hydraulic top link when half way extended.
