What tires should you get on a new Tractor, R1, R4, or Turf?
/ What tires should you get on a new Tractor, R1, R4, or Turf? #61
I have R4 tires on my NH TC30, and I use it for blowing snow with a front snow blower. I have a 1000 ft driveway, and I live in the snow belt on the east side of Lake Michigan. I would not put chains on, as I am concerned about doing damage to the concrete in front of barn and garage. When I have the snow blower on "float", I have very poor steering control, often have to lift it and back up and try again. When the temperature is around freezing, I have traction problems too, regardless of four wheel drive and diff lock. I don't know if Nokian makes snow tires to fit my tractor, but I would be interested to hear if anybody has tried the Hakkapeliitta tractor tires and how they compare to others.
/ What tires should you get on a new Tractor, R1, R4, or Turf? #62
Well I'm not here to argue with someone's experience, but I will say perhaps your issue is that you got worn tires.
At 1500+ hours, they are definitely worn. But they still have plenty of tread remaining. At something like $360 per tire, I'm not going to throw them out just because of a little wear.
/ What tires should you get on a new Tractor, R1, R4, or Turf? #63
Yeh, I hear ya. Do you have a finished driveway and worried about tearing it up with chains? If yeh, and this applies to John Mc up there too, you guys could try Terra Grips. I had them on a garden tractor when I was plowing with it, they worked great.
/ What tires should you get on a new Tractor, R1, R4, or Turf? #64
To the OP I know the L series has three or 4 different width configurations for the back tires and they are normally shipped in the narrow configuration. Talk to your dealer about moving your rear tires to the widest configuration possible. I have a L 3901 with R1s and the wider configuration makes a huge difference on stability. This Video helps explain-
/ What tires should you get on a new Tractor, R1, R4, or Turf? #65
Good point. On most brands, the width adjustable rims are only offered with R1 tires. So it's something else to keep in mind when choosing tires. With R1 Radials, most will actually offer front and rear witdth adjustable rims.
/ What tires should you get on a new Tractor, R1, R4, or Turf? #66
I'm not currently having traction problems because I use chains all winter long (and sometimes well beyond the winter season, depending on what I am doing). Most of our 1/4 mile driveway is gravel. We did pave the loop up near the house. I have not had problems with the studded chains damaging it. When it's cold out, damage only seems to happen when you spin the tires. With the Euro-style chains having constant contact with the ground, I have not had issues with the wheels spinning. I do stay off the paved area in the heat of the summer, since the studs would probably sink in when the asphalt was hot.
I used V-bar 4 link ladder chains for several years and V-bar Duo-Grip chains for one winter season. Both of them tended to have a slip-grab-slip-grab effect in icy conditions due to the spaces between cross links (especially the Duo-Grip, due to the larger spaces). It did not happen a lot, but I would see some spin under load. They would tend to gouge things up. Fortunately, we had not yet paved the driveway, and digging a little in the gravel was no big deal.
The old Craftsman garden tractor was always spinning it's tires, even with the 2-link V-bar ladder style chains, wheel weights, and a big bucket of sand on a platform on the back. By the time I add up the loader, filled rear tires, and forestry mods on my tractor (belly pan, limb risers, falling object protection) it weighs a little over 4000# even before I put the snow blower on the 3 Pt hitch, so it takes a bit more to spin the tires.
The terra grips look interesting, but I don't see them in sizes for larger tires. I wonder if they would pull apart in higher pull situations on larger vehicles?
/ What tires should you get on a new Tractor, R1, R4, or Turf? #67
The R 14 looks intriguining. I've used all three. The R1 tore up lawn when used there; the turf did well on the lawn, but I had to patch, plug and replace them all the time with some of my applicatioins. I'm one season into the R4 and really like them. I've not had any side stability issues, though I don't have much for hills to worry about.
From what i see, you are not experienced. Clearly you are pushing your boundaries past what they should be. There is ZERO way you could flip over a L3301 Kubota with r1 tires on the road by hitting bumps. You would have to be in the highest gear and do a 180 to roll. Plus, you said your new to tractoring so struggling to understand how you already have 2 tractors, but maybe im confused. Regardless, i would not recommend r4 tires. They are overrated. IMO the best are r14s. good traction, minimal turf damage and long life. If you must get r4s do not buy solideals. Look at titan/goodyear or carslile.
Already sank it down in the black sank and it went to tilt over, so had to pull it out with the JD, to say nothing of hitting the dips on the road. So yes, you can tip it over...
Here is a video on a tractor with the R14s....
/ What tires should you get on a new Tractor, R1, R4, or Turf? #70
R4s are all right on flat ground, but junk and highly dangerous on a slope, they will slide sideways, then bite for a couple seconds and tip the tractor up, I use turf, the old saying get what you pay for, turfs can be had in six ply, less chance of going flat from abrasion or nail, they bite better on a slope, on flat ground anything will work with tread
/ What tires should you get on a new Tractor, R1, R4, or Turf? #71
I like my turfs too; so far very good for mowing steep hills. Have had a leak or two on the fronts...think I'll check out the six-ply turfs when the time comes.
/ What tires should you get on a new Tractor, R1, R4, or Turf? #72
you got your kubota stuck in the asphalt? i Dont understand what you mean by "Already Sank It down in the black sank"
/ What tires should you get on a new Tractor, R1, R4, or Turf? #73
I just got done 4 days straight of driving over logs and stumps with R1’s carry logs and brush in my grapple.
No sidewall damage, no flats.
They make heavier R1’s for that type of work you know?
Heres actual log skidder tractor photos
These look a heck of a lot more like R-1s than R-4s
R-4s are great for use on pavement and compacted soils. R-1 s will do anything R-4s will except last as long on hard surfaces.
Conversely, R-4s will not do nearly as many tasks as well as R-1s.
For the average small tractor and hobbyist not going into deep mud or deep snow, R-4s are fine.
However, I can’t understand why anyone would want a tractor, being used for it’s true intent, which is traction, not having R-1’s. They enhance the tractors traction and utilize more of its pulling power. They sort of give you more drawbar HP which is what you want for pulling or pushing things
I’m not going to argue with your points, but I do want to point out that I’ve seen many, many log skidders and feller bunchers around here with R4 tires. They prefer them on rocky ground. Not all of the ground here is rocky, but there is enough that loggers prefer the R4 for when they have to work in that ground. Yes, I do also see the R4s with chains in the snow.
Black sand, my bad. It is like quicksand without the water. Till you hit it, you cannot imagine how fast you can go down. The trucks building my house sank in it and they had nothing that could get close enough to pull them out. They had to use a tow for 18 wheelers and run the cable all the way out to the trucks and pull.....
/ What tires should you get on a new Tractor, R1, R4, or Turf? #75
I love the Turf tires on my JD 790, but it seems they tend to pick up any nail or sharp object and puncture constantly. Thus when I got my L3301 I was ok to see R1 tires, but after almost tipping over just hitting bumps on the road, I am looking at the R4. What should you look for in a new tractor to start with or does it matter.
I've had R3 and R4. I will never buy anything else except R3s ever again.
/ What tires should you get on a new Tractor, R1, R4, or Turf? #76
Due to supply issues, I went with the R14s that came on the Kubota B2601. Absolutely NO tire problems on R4s since 2013. Had LOTS of front R3 turf problems on the 4010 but think the replacement, higher ply ones were probably better. Never had any problems but didn't have it long after putting the higher ply ones on. LOTS more side grip with the R3s. Forward/reverse grip seemed a tad better on R4s.
/ What tires should you get on a new Tractor, R1, R4, or Turf? #79
I can see that on rocky ground. Theres not much of a traction issue.
I’d venture to bet a large majority of log skidders run on R-1s though.
R-1 traction is unmatched. It utilizes your tractors available horsepower so much better.
I had a neighbor who hired a tree company to remove a bunch of trees. Got chipper truck stuck. Tried to pull it out with 4x4 utility tractor on R-4s and almost sank the tractor. I was able to walk them out on R-1s easily. The difference is amazing on soft ground or deep snow.
Never forget the thankful tree company owner saying something like “those 4” angled paddles on your AG tires make all the difference in the world”
/ What tires should you get on a new Tractor, R1, R4, or Turf? #80
My first year with R-3/Turfs after 20 years with R-4s and I am impressed with the traction and handling on snow roadways. So far no need to install chains but Im sure at some point a need could arise. I would caution venturing into wooded areas or mud however. Im mostly pasture, lawn and gravel road usage.
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
2015 FORD F-550 (A60736)
2015 FORD F-550...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A61567)
2002 Bobcat 863...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
FIFTH WHEEL ATTACHMENT PLATE (A60736)
FIFTH WHEEL...
