Grooving Industrial Tires
/ Grooving Industrial Tires #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
How hard is it to groove Industrial Tires?
What tools, how wide, how deep, unit of measure?
Assuming this will not decrease the life of the tire?
Might be a good summer project as a proactive measure.
TIA
Yooper Dave
/ Grooving Industrial Tires #2
With one of these I have heard it is not hard. There are a lot of other tire groovers also.
Tire groover.
/ Grooving Industrial Tires #3
Works great IMO, haven't had to use 4WD yet unless I'm on ice. Of course, haven't really had a good snow year so far. Ask again on Friday as we might get a good amount Wed and Thursday.
Here's my posting on it in OTT Does tire grooving really work?
/ Grooving Industrial Tires #4
I grooved the r4's on my last 2 tractors. The traction improvement is definitely noticable. For average snow amounts I am now able to plow up slopes that I had previously had to drive up and plow down. Sounds like a small thing, but plowing some 15 long rural drives, that efficiency matters.
I believe my iron is made by Ideal, and I cut my tires about 1/4" wide by 1/4" deep. Will it affect tire life? I suspect it does, as there is less rubber on the road. My previous machine had 1300 hours on grooved tires, and the rears were far from worn out and the fronts were getting there, but likely had another 500 hours of life.
For improved snow traction using r4's I highly recommend grooving.
There are a wide variety of patterns that people cut... I went with one groove down each lug.
/ Grooving Industrial Tires #5
/ Grooving Industrial Tires #6
I have an Ideal heated knife I used on once to groove my tires, I have to use chains none the less. PM me if someone is interested? I'll sell it $75.00 shipped anywhere in the lower 48.
/ Grooving Industrial Tires #7
The tires on my Kubota M59 are chunked pretty severely already from catching edges of stumps and misc stuff I may run across not visible in the snow...
By comparison @RjCorazza your tires look brand new.
I assume you didn't notice any additional chunking as I don't really see any right now anyway ???
/ Grooving Industrial Tires #8
@TWD
The front tires in the picture have about 600 hours on them, but were just grooved. The rears were grooved shortly after new.
I never had any chunks of tread coming off on my previous tractor that had somewhere around 1300 hours on the grooved tires.
I am either on pavement, grass, or dirt 99% of the time. No gravel, stumps, or rocks. I would imagine your service requirements are more severe than mine.
On edit: cool method on identifying a specific person with the @whomever. Much easier than quoting a message!
/ Grooving Industrial Tires #9
As mentioned, the Ideal Heated Knives Tire Groover, and I believe a number four blade. I think down about 1/4".
I picked one up used off Kijiji last summer, but misplaced the blades I ordered for it. Looking forward to this summer so I can do mine, versus the extra time it would take to do it this winter with the tires being darn cold. From what I've read, the warmer the tire, the easier to cut into it.
It would decrease the life of the tire, but as others mentioned as well in other posts, after hundreds or thousands of hours, nothing more than what would have normally worn, or not many chunks/lugs missing. It seems any extra wear is minimal, and the traction gained is well worth it.
/ Grooving Industrial Tires #10
I have used a panel cutter in an air hammer to re-groove tires. To make it cut better I replaced the cutting part with a piece of 1/4" tool bit stock. No burning rubber smell, nothing gets burned and the air does the work.
/ Grooving Industrial Tires #11
TIA
Yooper Dave
Is that the same as siping?
/ Grooving Industrial Tires #13
Is grooving better than siping? What is used to sipe(sp?) a tire? Jon
/ Grooving Industrial Tires #14
Siping is just cutting a line. Grooving cuts a small trench & actually removes rubber. Siping doesn't remove any rubber. Its suppose to let the tread flex a bit more & give more corners to dig in. Sipes are OEM on a lot of road tires these days. Basically a industrial razor blade or knife for siping. Grooving uses a U shaped chisel or heated U shaped knife.
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
2013 INTERNATIONAL DURASTAR 4400 FORESTRY BKT TRK (A63276)
2013 INTERNATIONAL...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
