Grooving Industrial Tires
   / Grooving Industrial Tires #11
How hard is it to groove Industrial Tires?
What tools, how wide, how deep, unit of measure?
Assuming this will not decrease the life of the tire?
Might be a good summer project as a proactive measure.
TIA
Yooper Dave
Is that the same as siping?
   / Grooving Industrial Tires #12
No, grooving tires is a little bit more intrusive.
   / Grooving Industrial Tires #13
Is grooving better than siping? What is used to sipe(sp?) a tire? Jon
   / Grooving Industrial Tires #14
Siping is just cutting a line. Grooving cuts a small trench & actually removes rubber. Siping doesn't remove any rubber. Its suppose to let the tread flex a bit more & give more corners to dig in. Sipes are OEM on a lot of road tires these days. Basically a industrial razor blade or knife for siping. Grooving uses a U shaped chisel or heated U shaped knife.
2021 JOHN DEERE 331G SKID STEER (A52709)
2021 JOHN DEERE...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
(2) AXLES (A52708)
(2) AXLES (A52708)
500BBL FRAC TANK (A58214)
500BBL FRAC TANK...
2024 John Deere 331G Skid Steer w/ WARRANTY! (A59213)
2024 John Deere...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
